arm64 kernel in development...!?
Posted: Tue Jun 21, 2016 9:03 pm
by ric96
The following article suggests that an arm64 kernel and a 64bit OS might be in development by linaro, I hope we get to play with it soon.
make that july 11th.
http://www.sequiturlabs.com/media_portf ... -community
Re: arm64 kernel in development...!?
Posted: Wed Jun 22, 2016 6:01 am
by fruitoftheloom
ric96 wrote:The following article suggests that an arm64 kernel and a 64bit OS might be in development by linaro, I hope we get to play with it soon.
Better late than never bother:
viewtopic.php?f=72&t=150956
Posted: Wed Jun 22, 2016 6:25 am
by ric96
aah.. remind me to visit the forums more often.
any ways viewtopic.php?f=63&t=152270
Posted: Wed Jun 22, 2016 9:40 am
by jamesh
It would help if that thread had a title that actually describes what the thread is about, in layman's terms.
Posted: Mon Aug 01, 2016 9:15 pm
by n0w4y
While it is uncertain what further 64-bit kernel development might be done, the
software mentioned in the announcement is available in preliminary form.
This is a repo/manifest build. There should be no need to hunt around
for appropriate commits or releases. Use of different repositories or
commits may or may not result in a working system.
The build/configuration is evolving. At present the rootfs/runtime is busybox
based but without a lot of effort an alternate 64-bit Linux runtime (eg., Ubuntu
or debian-like) works well.
Onboard wifi does not work. The kernel is based upon Electron752 git repository
from the bare-metal/aarch64 thread. There are no immediate plans to make onboard
wifi work. USB wifi dongles are known to work.
Make certain to satisfy build prerequisites outlined at:
https://github.com/OP-TEE/optee_os#41-prerequisites
Without these the build will most likely fail.
Follow the directions at:
https://github.com/OP-TEE/optee_os/blob ... on/rpi3.md
This is still a work in progress with many moving parts.
