Nicely summarised in this Adafruit blog.
Basically,
- miniaturised space probe, mass < 1g.
- "Solar" (Light) sail
- "BFG" type laser array on Earth, firing at sail on probe to propel it along.
- Tiny space probe accelerates to about 20% light speed.
(So, it doesn't need to go that far)" Focusing the light beam on the lightsail would accelerate individual nanocrafts to the target speed within minutes."
Active transmissions that distance are pretty hard to do. Swarms of bots or larger physical systems could use passive occultation of the local star on approach, and during the journey, opportunistic occultation of other stars as they are available. On approach, this could be combined with power generation.rzusman wrote:What is the point?
How is a 1g device going to transmit a signal back to Earth?
That could really work. One of the brilliant things about this is that you can attempt to solve some of the engineering problems yourself using hobbyist stuff. We could make a model of a starshot long range communication network on the school field using photodiodes, microbits, Pi Zeros (Where are these flippin' Zeros?jamesh wrote:Mesh network, just keep sending these things out, giving a stream of them to pass data back on.
Basic IoT....!
stderr wrote: But if you are going to get yourself going largely by local laser light here from our system, how do you slow down at the destination? Unless you accept that it is a fly by, this is the hardest part. If the laser is on the probes and uses power generated by its mechanism for occultation, perhaps that could work.
Apr 13, 2016 15:47 John McLean
At 0.2c, the craft would have no time to analyse the atmosphere before being vapourised. There is no feasible mechanism so far proposed to allow any meaningful amount of braking - bear in mind we are talking about using a 100 GW laser array to accelerate, which is several orders of magnitude greater than solar flux on earth. A flyby within 1AU would allow a spectroscopic analysis of the atmosphere and the opportunity for some photography. You'd hope to be able to identify moons orbiting an exoplanet, surface temperature, presence and composition of atmosphere, maybe evidence of geological activity. A lot of information can be gleaned without smashing into things.
I hope there is no space based infrastructure in the system where we are proposing to shotgun thousands of C fractional bullets.morphy_richards wrote:stderr wrote: But if you are going to get yourself going largely by local laser light here from our system, how do you slow down at the destination? Unless you accept that it is a fly by, this is the hardest part. If the laser is on the probes and uses power generated by its mechanism for occultation, perhaps that could work.Apr 13, 2016 15:47 John McLean
It'll be okay.BMS Doug wrote:I hope there is no space based infrastructure in the system where we are proposing to shotgun thousands of C fractional bullets.
That could be considered "unfriendly".
Space is vastly hugely mindbogglingly big. I mean you may think it’s a long way down the road to the chemist’s, but that’s just peanuts to space. *BMS Doug wrote:I hope there is no space based infrastructure in the system where we are proposing to shotgun thousands of C fractional bullets.morphy_richards wrote:stderr wrote: But if you are going to get yourself going largely by local laser light here from our system, how do you slow down at the destination? Unless you accept that it is a fly by, this is the hardest part. If the laser is on the probes and uses power generated by its mechanism for occultation, perhaps that could work.Apr 13, 2016 15:47 John McLean
that could be considered "unfriendly".
But this presupposes all parts of space are equally likely to receive the barrage, yet we are directing it exactly at a specific real target. Furthermore, it presupposes that gravity will not have any effect though it will, even given that the objects are perhaps flying at greater than the escape velocity of the Milky Way and especially if they are not, to wit, as time goes to infinity, it becomes increasingly likely, even outside of that spaceship that Zaphod stole, that it will be in fact right round one to one. And the expansion of the universe to make even more space in space will not save you for that expansion isn't in all things, not in us or anything else that is gravitationally bound, such as the galaxies and their clusters, rather only in those things that are not. So if the objects, the shards, the shrapnel, if they stay within the galaxy, they will fly around until they hit something, perhaps that something will be mad about it. Now do we have objects in the galaxy that are flying around at some fraction of C? The answer is yes we do, we call them "cosmic rays". Would you be mad at someone shooting at you with cosmic rays millions of times bigger than the normal ones? I know I would be. For the love of all things good in the world, halt this insane project right now!morphy_richards wrote:Space is vastly hugely mindbogglingly big. So they would probably just miss.I hope there is no space based infrastructure in the system where we are proposing to shotgun thousands of C fractional bullets.
You would have better like with power point presentation presenters, at least they actually have lasers, Lazer tag guns don't.peterlite wrote: What if we coordinated all the Lazer Tag players in the world to fire at the same spot in the sky. We throw a Zero in front of the lasers. We could create the critical first stage boost by coordinating some paint ball players to ...
Sure I know the chances of hitting something are infinitesimal, but consider that a truly space based civilisation could have lots of orbital traffic. What a lovely way to introduce ourselves, shooting a narrow target window (orbital flyby) with a large number of projectiles.morphy_richards wrote: Space is vastly hugely mindbogglingly big. I mean you may think it’s a long way down the road to the chemist’s, but that’s just peanuts to space. *
The ship is aimed to fly within 1AU of its target. 1 AU is 92 million miles. We can estimate the chances of a collision by projecting all the obsticles on a circle perpendicular to the flight-path. Given that the light sail is the largest part of the craft and is around 4 square metres, we find that the target circle is 18,000,000,000,000,000,000,000 times bigger than the craft. Of course the planet is probably the largest thing in there, and that's maybe 50,000,000 times as big as the craft. (8000km radius -- much bigger than Earth). Let's assume they have absolutely masses of orbital infrastructure equivilant to a whole other planet. So the target is 100,000,000 times bigger than the craft. But there is 1,800,000,000,000,000 times more room for the craft to be in that does not hit anything. So the chances of hitting anything in the target system is the reciprical of that, or 0.000,000,000,000,05% and the probability of missing everything is 99.999,999,999,999,95%.stderr wrote:But this presupposes all parts of space are equally likely to receive the barrage, yet we are directing it exactly at a specific real target. Furthermore, it presupposes that gravity will not have any effect though it will, even given that the objects are perhaps flying at greater than the escape velocity of the Milky Way and especially if they are not, to wit, as time goes to infinity, it becomes increasingly likely, even outside of that spaceship that Zaphod stole, that it will be in fact right round one to one. So if the objects, the shards, the shrapnel, if they stay within the galaxy, they will fly around until they hit something, perhaps that something will be mad about it.morphy_richards wrote:Space is vastly hugely mindbogglingly big. So they would probably just miss.I hope there is no space based infrastructure in the system where we are proposing to shotgun thousands of C fractional bullets.
A solar-system consists of the sun and noise -- everything else is negligible. So to hit our sun it would have to hit a circle of radius 695,700 metres in a circle of around 43,000,000,000,000,000 metres. That's a 99.999999998% chance of missing everything. It would have that chance on average once every twenty years. So the chance of missing everything for n years is 0.99999999998^(n/20). A brief bit of experimentation shows that in 20 billion years, it still has a 98% chance of missing everything.morphy_richards wrote:You're right, given enough time the likely hood of a collision with something else is 1.
when our great great great grandchildren are killed by angry aliens out for revenge I'm going to blame you!rurwin wrote: So we don't need to worry about someone suing us for at least twenty billion years and the Sun will eat the Earth in only four billion. By the time the miniscule chances of a hit are increased by the passage of time, the Sun will have burned out and we will either be dead or living somewhere else.
And (pleasingly) it's quite easy to do. As v to c is a simple ratio we can drop exact figures and use percentages, therefore full light speed "c" can be represented as 100 (%) and v at a quarter light speed can be represented as 25.t'=t √1-(v^2/c^2)
What will happen to aeroplanes flying over the beam?if I painted myself silver and stood in front of the beam
It wouldn't be pretty, but 5 minutes is not long to maintain an exclusion zone and there is a research project to look into the requirements.peterlite wrote:What will happen to aeroplanes flying over the beam?
