RaTTuS
Raspberry PI Running on 48Gb RAM
Thu Aug 16, 2012 2:26 pm
http://twitpic.com/ak51h8
also has a 650Gb Hard disk ...
but it's the RAM that's important
:lol:
Covfefe
woopderson
Re: Raspberry PI Running on 48Gb RAM
Thu Aug 16, 2012 3:07 pm
Say what??? How?
RaTTuS
Thu Aug 16, 2012 3:13 pm
see link .....
in original post
Covfefe
woopderson
Thu Aug 16, 2012 3:17 pm
derp, didn't see the other pictures posted.
riffraff
Fri Aug 17, 2012 7:41 am
Hardy har har. Verrrrry funny. :lol:
MysteryEntry
Sat Aug 18, 2012 10:18 am
That would be cool.
Keelyman
Sat Nov 24, 2012 4:04 pm
I saw the picture and have a basic idea of how it works, but could you go into more detail as to how it is hooked up?
RaTTuS
Sun Nov 25, 2012 10:09 am
Keelyman wrote:I saw the picture and have a basic idea of how it works, but could you go into more detail as to how it is hooked up?
I'll see if I can do another post monday ;)
Covfefe
morphy_richards
Sun Nov 25, 2012 4:05 pm
And its gravity assisted as well..... Sweeeeeeeeeet!
pygmy_giant
Sun Nov 25, 2012 4:34 pm
There's two empty slots - is that supposed to be ironic?
dan3008
Sun Nov 25, 2012 7:31 pm
Been looking at this for about the last 20 min trying to work out how to do it. Only just realised its a joke.
Still, should be possible to add additional ram to the pi shouldnt it?
I know a usb drive on windows can be used as ram, so why not on the pi?
dan3008 wrote:Pays your money, takes your choice
MrBunsy
Sun Nov 25, 2012 7:41 pm
You could add 'RAM' via usb, it's just next to useless as it's too slow. It'd basically be more swap space.
dan3008
Sun Nov 25, 2012 10:43 pm
Ah i see.
Not something ive ever tried, so i had no idea on speed
mmmm, I feel a play with a soldering iron and my soon to be redundent 215mb pi. See if i can work out some way of adding extra ram. Just for the hell of it, and ive nothing to lose.
mahjongg
Mon Nov 26, 2012 12:31 am
Well you have to loose a PI, and you will if you try to get the top (RAM) package off.
But go ahead its your PI, you can do what you want with it, even put it in a blender.
pygmy_giant
Mon Nov 26, 2012 2:19 am
I've got some diaries written by Adolf Hitler - anyoune interested in buying them?
dan3008
Mon Nov 26, 2012 1:26 pm
mahjongg wrote:Well you have to loose a PI, and you will if you try to get the top (RAM) package off.
I'd only do it to my orrigional, that i have obsolited, i recently got a newer one. So its been sat in a corner, doing nothing, since the new 512mb model is much better suited to my needs. Ok, so yes, i could lose a pi, but i might make something better. Who knows, I'm getting in touch with a friend at uni who is doing a masters in computing and electronics, getting his oppinion lol.
But either way, will be a fun little project.
mahjongg
Mon Nov 26, 2012 8:01 pm
well good luck with that, :shock: at least you will get a second opinion. :mrgreen:
Note that there is a reason that the RAM is directly connected to the SoC in this way, the kinds of speeds that are used for the interface signals mean that a cm length difference can make the RAM to fail.
Forget about trying to connect regular RAM too, as the PI needs RAM with a specific interface.
The only real possibility the PI would get 1G RAM (more is impossible, as the SoC can only address 1GB) is if someone starts making the right kind of POP RAM, and even if such a chip would exists it would be nearly impossible to replace the existing POP chip for another one.
I know, this will only make you more determined to try to proof me wrong :roll: but don't say you were not warned. :ugeek:
dan3008
Mon Nov 26, 2012 9:43 pm
mahjongg wrote:I know, this will only make you more determined to try to proof me wrong :roll: but don't say you were not warned. :ugeek:
You know me so well :) lol
Na, I've actually just got in (been posting from my laptop in uni all day) and actually looked at my pi. and the chip in question... I dont fancy poking that with a soldering iron, bit above my paygrade as it were. However, I'm determined there must be some way to boost the pi's ram ... mmmm
I'll need to think on this...
mahjongg
Mon Nov 26, 2012 10:12 pm
Wishful thinking is a bitch isn't it. :lol:
dan3008
Mon Nov 26, 2012 10:50 pm
That it is, that it is.
To be honest, I when i first posted, I wasnt 100% sure on where the ram on the pi was, and thourght that it would be possible to remove it safely, yeh, not a chance
mahjongg
Mon Nov 26, 2012 10:53 pm
Well physical RAM cannot be altered, but software tricks do exist, and some are implemented as standard in linux, such as swap space. There is also something called Z-RAM, but all these solutions have one big disadvantage, the swap RAM space for speed.
on the PI swapping to the SD-card is disabled, as it would quickly use up the write cycles of the flash in the card, and would also be extremely slow, even for swap space, just maybe using some kind of RAM swap device would be possible to implement that uses the SPI interface. Which can theoretically transfer 20 Mbps (2.5MBps).
RaTTuS
Tue Nov 27, 2012 9:21 am
I think the RPI is limited to 512Mb - as the way the SOC is designed only half of the max is available ...
as to the new pictures .... soon I promise .... I may even be able to double it .... [ha]
yes the pictures where a joke - as I had 48 1GB sticks left over from an upgrade.,..,
but I have a new camera and should be able to arrange a better picture ... not today though
Covfefe
NigelJK
Tue Nov 27, 2012 6:12 pm
Have a look at the RiscOS forum, 512megs is massive! If the software you're running is bloated (for no apparent reason other than to sell more ram) then I'd suggest it's the software that is at fault.
MrBunsy
Tue Nov 27, 2012 6:21 pm
NigelJK wrote:Have a look at the RiscOS forum, 512megs is massive! If the software you're running is bloated (for no apparent reason other than to sell more ram) then I'd suggest it's the software that is at fault.
Hardware is cheap, good programmers are expensive :P
Tue Nov 27, 2012 6:23 pm
Technically, the SoC is limited to 1GB, BUT there are NO PoP RAM packages in existence that have the right number number of address lines to get to the 1GB, so the current limit is 512MB. If someone wanted to it would be possible to make one, but that would be a very expensive thing to do indeed.
Return to “Off topic discussion”
