I have come across some alternative phrases for well know expressions.
I assume the following are well know:
"The excrement hit the rotational air displacer"
and
"You're navigating a smelly stream without propulsion device"
Anybody has more examples?
- Gert van Loo
- Contact: Website
- jackokring
- Contact: ICQ
Re: Alternative phrases
"The flattened square carbohydrate of heated and slightly caramel tone, always migrates through gravitation toward the local certain mass density with the exposure of the melted hydrophobic topping in a most hair adhesive orientation."
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
- MadHorseman
- Contact: Website
Th eversion I heard was:-Gert van Loo wrote:I have come across some alternative phrases for well know expressions.
and
"The ordure encountered an air-moving device."
- Gert van Loo
- Contact: Website
My knowledge of English phrases is not good enough to translate that one.jackokring wrote:"The flattened square carbohydrate of heated and slightly caramel tone, always migrates through gravitation toward the local certain mass density with the exposure of the melted hydrophobic topping in a most hair adhesive orientation."
Please enlighten me.
"I could be chasing an untamed ornithoid without cause."
I believe that one is meant to be something like "The toast always falls butter-side down".Gert van Loo wrote:My knowledge of English phrases is not good enough to translate that one.
"She was built like a forcfield latrine"
Eric Frank Russel
Eric Frank Russel
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
- Contact: Website
As inexpensive as deep-fried sticks of potato...
(Or, Cheap as chips, as an overgrown umpalumpa antiques expert likes to say)
I'm looking the cat out of the tree
That hits side nor shore
You harvest what you sow
The clock doesn't tick the same anywhere like it does at home
Butter with the fish
The monkey comes out of the sleeve
Throwing away the child with the bathing water
Holding a hand above someone's head
