I've been wondering about Moore's law, that the speed of computers are said to double approximately every 18 months.
Will this apply to new generations of Raspberry Pi's or is this law now obsolete?
I think moore was talking about x86/x64 archiecture computers.Woll wrote:I've been wondering about Moore's law, that the speed of computers are said to double approximately every 18 months.
I think moore was talking about x86/x64 archiecture computers.expendables wrote:Will this apply to new generations of Raspberry Pi's or is this law now obsolete?
Did the x86/x64 archiecture (sic) exist in 1965? or even 1975 when he revised the "law"rpdom wrote:I think moore was talking about x86/x64 archiecture computers.expendables wrote:Will this apply to new generations of Raspberry Pi's or is this law now obsolete?
Well the grand-daddy of the x86 the 4004 was released 1971expandables wrote:Moore was looking into the future and it was known at that time that he had the DeLorean.rpdom wrote:I think moore was talking about x86/x64 archiecture computers.expendables wrote:Will this apply to new generations of Raspberry Pi's or is this law now obsolete?
Moore was looking into the future and it was known at that time that he had the DeLorean.[/quote]expandables wrote:Did the x86/x64 archiecture (sic) exist in 1965? or even 1975 when he revised the "law"rpdom wrote:I think moore was talking about x86/x64 archiecture computers.expendables wrote:Will this apply to new generations of Raspberry Pi's or is this law now obsolete?
I agree. Right now, going to 28nm makes a lot of sense. This is a lot of performance to be wrung out of 28nm before going smaller That's why I said that there are going to be a lot of generations of chips in future (20 years? 30 years? I probably won't live long enough to see it.) of Pis before the problems Intel is facing become an issue for the Pi.gsh wrote:Actually no you are wrong, the cost to create a set of masks is now around 10x at 10nm what it costs at 40nm but the extra transistors you get per mm2 doesn't make up for it. So it's not efficient unless you're earning massive markups (i.e. Intel) or you need the high speed (Intel) and don't care about the power consumption (Intel)
Currently the sweet spot is 28nm so an improvement is available. But you still need to dig up $5m to create a new chip
Gordon
I suspect there is still life in steam power yet. We just don't spend any money developing it for everyday use, and after all, steam turbines produce all our electricity.Woll wrote:W. H. Heydt, if technology is reaching its design limits, is it restricted in what it can do? Much the same as you can only do so much with steam power?
It's not a case of "technology reaching it's limits". It's a matter of this particular technology reaching a limit of how small circuit elements can be (and at what level does it cease to be economically viable to go smaller). We've already seen (as Gordon noted) a "wall" on clock speed. That was actually driven by the thermal dissipation issue.Woll wrote:W. H. Haydt, if technology is reaching its design limits, is it restricted in what it can do? Much the same as you can only do so much with steam power?
No gas turbine "peaker" plants?jamesh wrote:I suspect there is still life in steam power yet. We just don't spend any money developing it for everyday use, and after all, steam turbines produce all our electricity.Woll wrote:W. H. Heydt, if technology is reaching its design limits, is it restricted in what it can do? Much the same as you can only do so much with steam power?
What? Did you think the reactor provided electricity directly? The reactor is just heat source...a replacement for coal or oil. (It's also one of the few energy sources we've got that isn't--even indirectly--derived from sunlight, and the others aren't being used very much so far. I will leave it as an exercise for the reader to determine how coal and oil are derived.)Woll wrote:Chips will go the same way as big CRT televisions. A slight change in the way things are done will do to chips what LED TVs did to televisions.
Jamesh, I was amazed to see on a recent TV documentary about Sellafield that steam turbines were used in nuclear power plants.
I think that's actually not entirely true, since IIRC all those nicely radioactive elements were created in supernovae and so doin a sense stem from starlight.W. H. Heydt wrote:The reactor is just heat source...a replacement for coal or oil. (It's also one of the few energy sources we've got that isn't--even indirectly--derived from sunlight,
But the starlight came from fusion....everything came from the big bang really.timrowledge wrote:I think that's actually not entirely true, since IIRC all those nicely radioactive elements were created in supernovae and so doin a sense stem from starlight.W. H. Heydt wrote:The reactor is just heat source...a replacement for coal or oil. (It's also one of the few energy sources we've got that isn't--even indirectly--derived from sunlight,
Isn't there a project in Scotland to install a tidal power system? Or is that somewhere else and I have a memory leak?jamesh wrote:But the starlight came from fusion....everything came from the big bang really.timrowledge wrote:I think that's actually not entirely true, since IIRC all those nicely radioactive elements were created in supernovae and so doin a sense stem from starlight.W. H. Heydt wrote:The reactor is just heat source...a replacement for coal or oil. (It's also one of the few energy sources we've got that isn't--even indirectly--derived from sunlight,
And I should add that I completely forgot about Hydro, wind turbines, solar, and certain gas power stations when I said all our electricity came via stream turbines. Apologies.
The clock speed and power dissipation of the SoC the Pis use is low enough that simple convective airflow will keep it with its thermal limits.Woll wrote:W. H. Heydt, thanks for your reply. It's interesting to see your answers because I'm not in this field of work. I wondered why the Raspberry Pi never had a heat sink.
That's interesting. Did you have particular idea how it was done or was it a case of "nuclear reactor' == something == "electric power out" without thinking about what the "something" is?And no, I didn't think they relied on steam in nuclear power plants. The program was very interesting.
