Only for the criminally insane. Java is the way to go.expandables wrote:I guess c++ is the way to go
ALGOL uses for.expandables wrote:What programming language i can learn to make hundreds an hour?
Well what do you already know? Do you know a place to advertise it? Do you have experience? People with experience get payed more. What projects would you take on? What are your skills?expandables wrote:I am serious![]()
ALGOL is used on Unisys A-series (or it was twenty+ years ago when I dabbled with those)morphy_richards wrote: ALGOL uses for.
Fortran uses do.
Cobol uses perform varying.
+1ShiftPlusOne wrote:If someone is willing to pay you hundreds per hour, it won't be for the choice of language.
If there is such a reward for knowing a particular language it is likely that language is extremely obscure and/or esoteric. But which of those will prove to be a winner ? It is going to be a bit of a gamble that you choose the right one and there is someone willing to make you rich for knowing it. You might have to learn them all and may still never strike it rich.expandables wrote:What programming language i can learn to make hundreds an hour?
http://www.theregister.co.uk/2015/10/31 ... r_fortran/hippy wrote: If there is such a reward for knowing a particular language it is likely that language is extremely obscure and/or esoteric.
The problem isn't knowing FORTRAN, it's knowing whatever obscure assembly language that was used. And, of course, writing tight enough code to fit in a small amount of memory.DougieLawson wrote:http://www.theregister.co.uk/2015/10/31 ... r_fortran/hippy wrote: If there is such a reward for knowing a particular language it is likely that language is extremely obscure and/or esoteric.
that's about as obscure as you'll get. Re-programming the Voyager 1 mission with code that was obsolete in 1977.
Sorry about the link to El Reg.
Okay...I haven't used this in at least 40 years... In order to restart Monitor IID on an IBM 1620 Mod. I, at the console, press "Instant Stop", "Insert", they type (on the console typewriter), "4900796<release/start>". Having a "sticky" memory or odd details is very useful for a programmer, but the data you remember may not be useful later.expandables wrote:I am reading couple books and learning some programming languages and also learning the Linux command line. I don't find anything difficult i just find it hard to remember "codes".
kusti8 wrote: Well what do you already know?
Their common problem is
That they're not someone else
Yea MJ collects all my packagesame wrote:Wow! Amazon delivers to Neverland?
