Linkan
Connecting IR Infrared Board Plate to PSU not working
Sun Nov 01, 2015 5:35 pm
Hi, I am trying to connect this with this 12V 2A stabilized dc power supply.
For some reason the IR plate doesn't draw any current and I suspect it is broken. Even with the light sensor completely covered non of the IR leds light up.
This is the board which looks fine IMO
Any ideas why it doesn't draw any current?
MrEngman
Re: Connecting
Sun Nov 01, 2015 5:41 pm
On the PCB next to the power connector it says +12v and this is next to the BLACK wire on the power connector by the look of it. Have you got your power supply connected the right way. Won't the red wire be +12v?
MrEngman
Linkan
Re: Connecting
Sun Nov 01, 2015 5:44 pm
MrEngman wrote:On the PCB next to the power connector it says +12v and this is next to the BLACK wire on the power connector by the look of it. Have you got your power supply connected the right way. Won't the red wire be +12v?
MrEngman
Ah, that was it! That was really simple, sorry for wasting your time. The color codes on the wire was reversed...
Return to “Off topic discussion”
