davidsstar
Lubuntu network configuration -- Help!?
Mon Jul 20, 2015 9:18 pm
I'm running Lubuntu on my laptop and raspbian on a raspberry pi. In the process of trying to share the wifi interconnection with my raspberry, over ethernet cable, I've messed up my network settings. Would anyone be willing to help me troubleshoot this with me?
Lubuntu settings:
ifconfig:
eth0      Link encap:Ethernet  HWaddr 78:ac:c0:41:ff:22
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:2927 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2927 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:270261 (270.2 KB)  TX bytes:270261 (270.2 KB)
wlan0     Link encap:Ethernet  HWaddr 1c:65:9d:6d:15:c5
          inet addr:192.168.1.3  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::1e65:9dff:fe6d:15c5/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12910 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7288 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13598617 (13.5 MB)  TX bytes:1263908 (1.2 MB)
sudo nano /etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.1.100
netmask 255.255.255.0
sudo nano /etc/NetworkManager/NetworkManager.conf:
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
no-auto-default=78:AC:C0:41:FF:22,
[ifupdown]
managed=true
cat /etc/udev/rules.d/70-persistent-net.rules:
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x10ec:0x8136 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="78:ac:c0:41:ff:22", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x10ec:0x8171 (rtl8192se)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="1c:65:9d:6d:15:c5", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
david@david-compaq-Xubuntu:~$
/etc/dhcp/dhclient.conf:
# Configuration file for /sbin/dhclient, which is included in Debian's
#       dhcp3-client package.
# This is a sample configuration file for dhclient. See dhclient.conf's
#       man page for more information about the syntax of this file
#       and a more comprehensive list of the parameters understood by
#       dhclient.
# Normally, if the DHCP server provides reasonable information and does
#       not leave anything out (like the domain name, for example), then
#       few changes must be made to this file, if any.
option rfc3442-classless-static-routes code 121 = array of unsigned integer 8;
#send host-name "andare.fugue.com";
send host-name = gethostname();
#send dhcp-client-identifier 1:0:a0:24:ab:fb:9c;
#send dhcp-lease-time 3600;
#supersede domain-name "fugue.com home.vix.com";
prepend domain-name-servers 127.0.0.1;
request subnet-mask, broadcast-address, time-offset, routers,
        domain-name, domain-name-servers, domain-search, host-name,
        dhcp6.name-servers, dhcp6.domain-search,
        netbios-name-servers, netbios-scope, interface-mtu,
        rfc3442-classless-static-routes, ntp-servers,
        dhcp6.fqdn, dhcp6.sntp-servers;
#require subnet-mask, domain-name-servers;
#timeout 60;
#timeout 60;
#retry 60;
#reboot 10;
#select-timeout 5;
#initial-interval 2;
#script "/etc/dhcp3/dhclient-script";
#media "-link0 -link1 -link2", "link0 link1";
#reject 192.33.137.209;
#alias {
#  interface "eth0";
#reboot 10;
#select-timeout 5;
#alias {
#  interface "eth0";
#  fixed-address 192.5.5.213;
#  option subnet-mask 255.255.255.255;
#lease {
#  interface "eth0";
#  fixed-address 192.33.137.200;
#  medium "link0 link1";
#  option host-name "andare.swiftmedia.com";
#  option subnet-mask 255.255.255.0;
#lease {
#  interface "eth0";
#  option broadcast-address 192.33.137.255;
#  option routers 192.33.137.250;
#  option domain-name-servers 127.0.0.1;
#  renew 2 2000/1/12 00:00:01;
#  rebind 2 2000/1/12 00:00:01;
#  expire 2 2000/1/12 00:00:01;
At some point I also ran the commands:
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo iptables --append FORWARD --in-interface eth0 -j ACCEPT
sudo iptables --table nat --append POSTROUTING --out-interface wlan0 -j MASQUERADE
Right now the ethernet connection seems to be disabled according to GUI
Raspbian settings:
auto lo
auto eth0
address 192.168.1.222
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
Return to “Off topic discussion”
