What I need is sensor 1 voltage - sensor 2 voltage on the output. I've checked the voltage followers and they are working as expected. I'm using UA741 op amps with +10.5V Vcc+ and 0V Vcc- I also have the bias pins grounded
Here's my schematic:
Not as "Simples" as your analysis though !drgeoff wrote:The gain of the final stage for signal from the top follower is 1. (Negative feedback.)
The gain of the final stage for signal from the bottom follower is 0.5. (3.3k and 3.3k divider, then voltage follower).
So you are trying to have 2.6 volts on -ve input and 1.3 on +ve input of the final op-amp.
Try removing the 3.3k resistor to ground from the +ve input of final op-amp. You may even be able to also dispense with the other 3.3k resistor on that +ve input.
Simples?
I'd suggest two resistors of twice the value, one to ground and the other to 5v.... return the currently grounded end of the 3k3 resistor to 2.6 volts instead.
Two 3K3 resistors in series makes a 6K6.Burngate wrote: But they don't make 6k6 resistors ... which is irritating.
