epicatsup
Can you put a Nintendo switch psu over RPI400 GPIO?
Wed Mar 10, 2021 5:46 pm
I just thought of putting a Nintendo switch charger on GPIO of rpi400. Would it create magic smoke efficiently :?: :twisted:
drgeoff
Re: Can you put a Nintendo switch psu over RPI400 GPIO?
Wed Mar 10, 2021 5:53 pm
Why go to the trouble of somehow connecting it to the GPIO header when its USB-C plug can simply be inserted into the USB-C socket of the RPi400? The result will be exactly the same.
Quis custodiet ipsos custodes?
LTolledo
Wed Mar 10, 2021 9:30 pm
physically just placing over the GPIO? not connecting it?
it wont create magic smoke... as I have confirmed on my RPi4B :mrgreen:
Nintendo Switch PSU over RPi GPIO.jpg (180.01 KiB) Viewed 1053 times
however...if you want to use it to power the RPi400 (note: I did not tried this so there are no guarantees from me)
just connect the Nintendo switch PSU's USB-C plug the RPi's USB-C port....
dont forget to plug the AC side of the PSU.... otherwise the RPi400 wont start... :D
Some people be like:
davidcoton
Wed Mar 10, 2021 10:38 pm
No, and No.
The GPIO header cannot be used to power the Pi400, there is a blocking switch.
epicatsup
Thu Mar 11, 2021 1:19 am
:roll: :lol: Not quite what I meant,but ok
epicatsup
Thu Mar 11, 2021 1:22 am
No, and No.
i was short on time so i didnt have time to say this but what i ment to say was "by bypassing the USB-C power diode"
davidcoton
Thu Mar 11, 2021 10:06 am
No, and No.
Well, if you miss out critical bits of the question, the answers you get will be inappropriate, if not wrong.
Please don't waste our time like that, put ALL the information you know to be relevant in your FIRST question.
Revised answer: IDK. Try it at your own risk. Have a camera ready to capture any escaping magic smoke.
[offtopic]
I once saw an experiment to determine how much magic smoke was in a 741 op-amp, by applying +/- 30V power. The answer -- lots. Then some. :o :shock:
[/offtopic]
bensimmo
Thu Mar 11, 2021 10:07 am
Waste time, it's been a fun thread :-)
Try it?
It will power an original Pi4 with full 10" USB-C Picade setup from the USB-C socket on the Pi4.
It will knot power it from the Picade additional USB-C socket there for convenience (I think as its on the side needed to access it) on the PicadeX hat.
It does power the Pi4* using a USB to USB-C cable, long 3m Aliexpress Special and even a 5A Purple tabbed Huawei one that works with nothing so far, especially most chargers) using either of the three USB out on the Switch caddy.
*it didn't provide enough power to power the 10" screen with the Picade setup, it tried but kept loosing the screen as the screens board turned off.
Pi4 was fine though.
mahjongg
Mon Aug 02, 2021 1:06 pm
I guess the intended switch supply has a type C USB port?!
if so, what does the supply state the output voltage is? does it say 5V DC? if not or nothing it mentioned it isn't certain the supply will deliver 5V, it might try to negotiate a higher voltage, which will fail with a PI4, theoretically the supply should then switch back to 5V, but that is theory, not certainty, I would not risk it.
Simply buy the official supply, its cheap and works well.
bensimmo
Mon Aug 02, 2021 6:07 pm
USB-C
5v 1.5A (used for charging joycons)
and 15V 2.6A for charging and powering the Switch in it's dock.
Hence it is the PSU for the dock.
The Switch itself will happily run from a 5V 3A supply directly, it quite likes the Pi supply.
the Switch Dock on the other hand does stuff with the supply as needed with some gubbins on the Docks circuitboard.
The Pi will only see the 5v supply. A bit underpowered for a modern Pi though. 2.5A at a minimum iirc* with no USB, 3.0A for general use.
I wonder is epicatsup tried it 6months ago.
*as stated by RPi and the adaptor for using the older Pi3 supplies.
LTolledo
Wed Aug 04, 2021 9:48 am
Lemme see....hmmm
Nintendo Switch PSU: USD 15.00
Official RPF PSU for RPi4B: USD 8.00
if $8.00 is "more expensive" than $15.00 then I give up! :(
cleverca22
Wed Aug 04, 2021 9:57 am
Lemme see....hmmm
but if you happen to already have a switch psu, then thats comparing $0 to $8
mahjongg
Wed Aug 04, 2021 10:29 am
The true cost is the cost of buying a new RPI400 if the Nintendo PSU blows up the RPI400, which has a non-zero chance, so is the risk worth $8 ?
cleverca22
Wed Aug 04, 2021 10:35 am
the switch psu uses usb-c to feed power into the dock
the switch and dock then use usb-c to exchange usb3.0 and hdmi
id bet that all of those parts are following the usb-c specs, and shouldnt blow up any other usb-c device following the specs
Return to “Off topic discussion”
