seskc1
Wireless Key fob
Mon Aug 02, 2021 7:43 pm
Hello, sorry am a complete novice. I have a Raspberry Pi 4b which will not connect to/recognise a Universal Cloning Wireless Remote Control Key Fob for Car Garage Door Gate Fixed code 433mhz. Further described as: A fixed-frequency remote clone (433.92mhz) for copying 99.99% of the common fixed and learning code remotes.
Is it possible to connect to any key fob which would be used to remotely turn Pi 4b on/off for example?
Thank you.
Amazon link to key fob:
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
drgeoff
Re: Wireless Key fob
Mon Aug 02, 2021 8:54 pm
Not clear what you are trying to do. No RPi has a wireless receiver or transmitter for frequencies around 433 MHz.
Quis custodiet ipsos custodes?
KeithMck
Tue Aug 03, 2021 12:33 pm
No.
At least, not directly, you may be able to, if you have a receiver for those fobs wired into the power supply for the RPi4.
W. H. Heydt
Tue Aug 03, 2021 4:45 pm
No.
That would be a bad way to do it. Suddenly dropping power on running system will--sooner or later--give you a corrupted file system. Better to attach the receiver to the Pi and have the signal cause a system shutdown.
KeithMck
Tue Aug 03, 2021 6:00 pm
I defer to W.H.Heydt, who has much more experience than I, about such things... 8-)
drgeoff
Tue Aug 03, 2021 8:40 pm
And a system shutdown does not turn a RPi off if your meaning of "off" is that the RPi stops drawing any current from its power source.
seskc1
Mon Aug 09, 2021 7:54 pm
Thank you for your help.
Return to “Off topic discussion”
