W. H. Heydt
Coming to RPiOS...soon?
Wed Jun 16, 2021 4:36 pm
https://www.theregister.com/2021/06/16/debian_11/
Apparently, the freeze date for Debian 11 (Bullseye) is 17 July.
thatchunkylad198966
Re: Coming to RPiOS...soon?
Wed Jun 16, 2021 4:59 pm
How long after the freeze do they release?
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
trejan
Wed Jun 16, 2021 5:01 pm
~4 months for the last few versions.
thatchunkylad198966
Wed Jun 16, 2021 5:11 pm
Still quite a while then.
bls
Wed Jun 16, 2021 5:53 pm
Indeed, but assuming that there are some "test" or "preview" RasPiOS builds, gives people time to get stuff working on the new release. That said, I've started testing my stuff on the April Debian Bullseye Pi build and haven't run into any major issues yet.
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
geev03
Thu Jun 17, 2021 10:14 am
https://raspi.debian.net/tested-images/
Working as expected..
root@rpi4-20210413:/home/pi# neofetch --off
pi@rpi4-20210413
OS: Debian GNU/Linux 11 (bullseye) aarch64
Host: Raspberry Pi 4 Model B Rev 1.4
Kernel: 5.10.0-5-arm64
Uptime: 29 mins
Packages: 267 (dpkg)
Shell: bash 5.1.4
Terminal: /dev/pts/0
CPU: (4) @ 1.500GHz
Memory: 172MiB / 7808MiB
thatchunkylad198966
Thu Jun 17, 2021 10:28 am
pi@rpi4-20210413
Uptime: 29 mins
Shell: bash 5.1.4
CPU: (4) @ 1.500GHz
You tried the daily images?
https://raspi.debian.net/daily-images/
Thu Jun 17, 2021 11:12 am
pi@rpi4-20210413
Uptime: 29 mins
Shell: bash 5.1.4
CPU: (4) @ 1.500GHz
Users beware about images offered:
This site is not an official Debian project. While the maintainer (Gunnar Wolf) is a Debian Developer, content herein provided should be considered unofficial. Web site source code is available.
thatchunkylad198966
Thu Jun 17, 2021 1:04 pm
pi@rpi4-20210413
Uptime: 29 mins
Shell: bash 5.1.4
CPU: (4) @ 1.500GHz
Yes; just like forums.debian.net isn't official. I think we all know this already.
KeithMck
Thu Jun 17, 2021 2:41 pm
Just read in another post, RPi5 details almost sorted out - wonder how long the process will be from details to hardware....I'm guessing somewhere in about 2 years - hope I can still afford one... :mrgreen:
(No, I'm not even going to guess what it will be...... :D )
thatchunkylad198966
Thu Jun 17, 2021 2:51 pm
I was about to reply to that thread, refreshed and it was locked. :lol: :mrgreen:
gordon77
Thu Jun 17, 2021 3:16 pm
https://www.techrepublic.com/article/ra ... oing-next/
When Eben was asked Does that mean no imminent plans for a Raspberry Pi 5, then? "We're thinking about it. We're not quite sure what it'll look like yet," he says.
geev03
Thu Jun 17, 2021 3:34 pm
pi@rpi4-20210413
Uptime: 29 mins
Shell: bash 5.1.4
CPU: (4) @ 1.500GHz
No. IT was "20210413".
However the official Debian 11, via netinstall , is preferable as everything just works ...
root@raspberrypi
Host: Raspberry Pi 4 Model B D03114
Kernel: 5.10.0-7-arm64
Uptime: 16 mins
Packages: 1279 (dpkg)
Shell: bash 5.1.4
Resolution: 1920x1080
DE: Xfce 4.16
WM: Xfwm4
WM Theme: Default
Theme: Xfce [GTK2], Adwaita [GTK3]
Icons: Tango [GTK2], Adwaita [GTK3]
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: (4)
Memory: 1104MiB / 7799MiB
craigevil
Thu Jun 17, 2021 4:10 pm
I am too lazy to mess with the Debian images. I installed RPIOS arm64, added Debian unstable repo ,
ran apt update; apt full-upgrade, added the rpios bullseye repo, update/upgraded, then ran rpi-update.
All is good.
pi@raspberrypi
Host: Raspberry Pi 400 Rev 1.0
Kernel: 5.10.43-v8+
Uptime: 1 day, 2 hours, 51 mins
Packages: 2316 (dpkg), 9 (flatpak)
Shell: bash 5.1.8
DE: MATE 1.24.1
WM: Metacity (Marco)
Theme: Sweet-Dark [GTK2/3]
Icons: BeautyLine [GTK2/3]
Terminal: guake
CPU: BCM2835 (4) @ 2.200GHz
Memory: 1484MiB / 3794MiB
My sources.list and raspi.list:
# /etc/apt/sources.list.d/raspi.list
deb https://archive.raspberrypi.org/debian/ buster main
# deb-src https://archive.raspberrypi.org/debian/ buster main
deb https://archive.raspberrypi.org/debian/ bullseye main
# deb-src https://archive.raspberrypi.org/debian/ bullseye main
deb https://deb.debian.org/debian unstable main contrib non-free
# deb-src https://deb.debian.org/debian unstable main contrib non-free
# Experimental See: http://wiki.debian.org/DebianExperimental
deb https://deb.debian.org/debian experimental main contrib non-free
# deb-src https://deb.debian.org/debian experimental main contrib non-free
# Incoming https://incoming.debian.org/
# deb https://incoming.debian.org/debian-buildd buildd-unstable main contrib non-free
# Testing (Bullseye) https://www.debian.org/releases/bullseye/arm64/release-notes/ch-upgrading.en.html
# deb https://deb.debian.org/debian testing main contrib non-free
# deb-src https://deb.debian.org/debian testing main contrib non-free
Full inxi -Ffxxxz
System:    Kernel: 5.10.43-v8+ aarch64 bits: 64 compiler: N/A Desktop: MATE 1.24.1 info: mate-panel, plank wm: marco 1.24.1
           vt: 7 dm: LightDM 1.26.0 Distro: Raspberry Pi OS base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: ARM Device System: Raspberry Pi 400 Rev 1.0 details: BCM2835 rev: c03130 serial: <filter>
CPU:       Info: Quad Core model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8 rev: 3 bogomips: 432
           Speed: 2200 MHz max: 2200 MHz Core speeds (MHz): 1: 2200 2: 2200 3: 2200 4: 2200
           Features: asimd cpuid crc32 evtstrm fp
Graphics:  Device-1: bcm2708-fb driver: bcm2708_fb v: kernel bus-ID: N/A chip-ID: brcm:soc class-ID: fb
           Device-2: bcm2711-hdmi0 driver: N/A bus-ID: N/A chip-ID: brcm:soc class-ID: hdmi
           Device-3: bcm2711-hdmi1 driver: N/A bus-ID: N/A chip-ID: brcm:soc class-ID: hdmi
           Display: x11 server: X.Org 1.20.11 compositor: marco v: 1.24.1 driver: loaded: fbdev unloaded: modesetting
           resolution: 1920x1080 s-dpi: 96
           OpenGL: renderer: llvmpipe (LLVM 11.0.1 128 bits) v: 4.5 Mesa 20.3.5 compat-v: 3.1 direct render: Yes
Audio:     Device-1: bcm2835-audio driver: bcm2835_audio bus-ID: N/A chip-ID: brcm:bcm2835_audio class-ID: bcm2835_audio
           Sound Server-1: ALSA v: k5.10.43-v8+ running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
Network:   Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A chip-ID: brcm:fe300000 class-ID: mmcnr
           IF: wlan0 state: up mac: <filter>
           Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A chip-ID: brcm:fd580000 class-ID: ethernet
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Bluetooth: Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000 class-ID: serial
           Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0 lmp-v: 5.0 sub-v: 6606 hci-v: 5.0
           rev: 36
Drives:    Local Storage: total: 936.93 GiB used: 118.2 GiB (12.6%)
           ID-1: /dev/mmcblk0 model: SD256 size: 238.3 GiB rotation: SSD serial: <filter> scheme: MBR
           ID-2: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1 size: 232.88 GiB serial: <filter> rev: 1.00 scheme: MBR
           ID-3: /dev/sdb type: USB vendor: Samsung model: PSSD T7 size: 465.76 GiB rotation: SSD serial: <filter> scheme: MBR
Partition: ID-1: / size: 458.2 GiB used: 47.52 GiB (10.4%) fs: ext4 dev: /dev/sdb2
           ID-2: /boot size: 252 MiB used: 47.9 MiB (19.0%) fs: vfat dev: /dev/sdb1
Swap:      ID-1: swap-1 type: file size: 100 MiB used: 0 KiB (0.0%) priority: -2 file: /var/swap
           ID-2: swap-2 type: zram size: 3 GiB used: 197.8 MiB (6.4%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 49.2 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 207 Uptime: 1d 2h 58m Memory: 3.78 GiB used: 1.84 GiB (48.8%) gpu: 76 MiB Init: systemd v: 247
           runlevel: 5 target: graphical.target Compilers: gcc: 10.2.1 alt: 10 Packages: 2325 apt: 2316 flatpak: 9 Shell: Bash
           v: 5.1.8 running-in: guake inxi: 3.3.04
Raspberry PI 400 Raspberry Pi OS (Unstable) Kernel: 5.10.17-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
W. H. Heydt
Thu Jun 17, 2021 10:20 pm
It's a pretty good bet that the base model list price will be $35.
(Since it's now been pretty much exactly 2 years since the Pi4B launched, I think it reasonable to expect the Pi5B in not much more than another year.)
pidd
Fri Jun 18, 2021 2:13 am
As its designed to a price even at concept stage, the hardware is probably pretty much fixed, possibly down to component supply chains, it maybe the software and documentation that will be the longest remaining part of development depending how much different the hardware is from existing products.
My sensors say they may be wary of producing a Pi500
craigevil
Fri Jun 18, 2021 5:24 am
Estimated release date from the people in the various #debian irc channels that are in the know, seem to think it will be released July 31st.
Return to “Off topic discussion”
