razzjazz192
Help identifying tiny chip
Tue May 11, 2021 1:37 am
Hi All,
I recently ordered a bunch of electronic components, and out of one of those packages, there was a little ziplock baggie with about five of these extremely tiny....well, I don't know exactly what it is, but it looks like a chip of some sort, something with connectors on the back, I'll have to post a pic of that later. I wondered if anyone has seen anything like this before, so that I might
know what to do with it. Here is an image. Thanks in advance for any info.[*]Image
scotty101
Re: Help identifying tiny chip
Tue May 11, 2021 8:41 am
Off topic but someone has already reported that.
How about a close up photo of this "thing" so that someone might actually stand a chance of identifying it?
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
MiscBits
Tue May 11, 2021 11:43 am
I would ask the supplier...
Is a computer language with goto's totally Wirth-less?
Tue May 11, 2021 3:34 pm
What is that picture?
It looks like you have cut and pasted an image of some chip or whatever into some other picture of a screen.
Perhaps it would help if you list here what that "bunch of electronic components" you ordered was.
pidd
Tue May 11, 2021 5:19 pm
Looks like a micro-miniature switch, what is on the other side? Who was the supplier? Its probably in their catalogue.
Burngate
Tue May 11, 2021 5:25 pm
I recently ordered a bunch of electronic components, and out of one of those packages, ...
Who from? What components? What else was in that package?
LTolledo
Tue May 11, 2021 9:42 pm
based on the image presented I can only identify it as a U.S.T.
"Unidentifiable Something Thingy"
:mrgreen:
Some people be like:
davidcoton
Tue May 11, 2021 9:55 pm
:mrgreen:
No, not one of them. It's clearly a Whotsit. Made by the Widget division of Acme Corp.
razzjazz192
Thu May 13, 2021 11:45 pm
I'll take better photos with my SLR in the morning and post them. It came in a package from sparkfun, I think, but I didn't see anything on their site like that. Now there's another chip almost as small, which I identified as some sort of onboard memory for cars.......I'll post that too. No copy and paste, I promise, it's a real...something
razzjazz192
Fri May 14, 2021 1:17 pm
Here are some more pictures. Pardon the dirty fingers--early morning gardening tasks. The chips are so small that even with a good camera, it's hard to get a clear image. At any rate, one of the chips has this identifying sequence: winbond 25032JVSIQ2017. That's the one with 8 pins, and I was able to follow that ID back to this website: https://www.winbond.com/hq/?__locale=en....very interesting stuff. Whoever suggested that the smaller chip is some sort of switch, I have a feeling you're right. It has two...I don't know what you'd call that...copper leads, inputs...and one output. The 8-pin chip looks like onboard ram for embedded devices....has anybody worked with this stuff? How would you ever solder any of this? I have helping hands and soldering kit with multiple fittings, but this is so tiny, and yet so interesting. I don't know...I only started learning this programming stuff because of the pandemic, and I very much like it.
razzjazz192
Fri May 14, 2021 1:18 pm
LTolledo
Fri May 14, 2021 8:59 pm
as mentioned in my previous post, due to the size of the image (for the "small chip") I'd still call it a U.S.T.
better drop sparkfun a mail and ask them personally what they actually sent you.
they should know better than anyone here in the forum
because the items came from sparkfun.
if they dont know what its is either... better demand that they accept a return of that batch of items sparkfun sent you.
use of U.S.T. on your project might be detrimental...
Gavinmc42
Fri May 14, 2021 11:44 pm
Seems to have a a clear top, could be a light sensor.
Only three pads so opto transistor or analog output.
Bingo
https://www.sparkfun.com/products/8688
I'm dancing on Rainbows.
jojopi
Sat May 15, 2021 1:55 am
They are intended for reflow soldering. You would have a PCB with matching pad layouts, apply solder paste to the PCB pads using a stencil, place the parts on top, then heat the whole part, or the whole board. Each glob of paste melts into a ball of solder, and the surface tension should correct for any slight misalignments.
If the pads are restricted to the edges of the part, then it is just about possible to heat them with an iron and feed solder underneath by capillary action. Again you would need a good quality PCB with the correct footprints.
mahjongg
Sat May 15, 2021 2:09 pm
My educated guess is that it is a dual LED, with two anodes and one cathode, probably a red and a green LED in one package. the shape of the copper at the one contact side suggests that side is the Cathode.
try with a multimeter in the "diode" setting, to see if you can light up the leds.
There is no text readable on the eight-pin SO chip, perhaps if you shine light on it from an angle you can read what is laser printed on it with a magnifying glass.
gordon77
Sat May 15, 2021 2:19 pm
Gavinmc42 has identified it https://www.sparkfun.com/products/8688
basically a transistor with a clear top to detect light https://www.vishay.com/docs/81579/temt6000.pdf
rpdom
Sat May 15, 2021 3:36 pm
That brings back memories of scratching the paint off an OC71 to turn it into an OCP71 :-)
Unreadable squiggle
pidd
Sat May 15, 2021 3:51 pm
OCP71's are cheaper than OC71's these days so the process might be getting reversed.
gordon77
Sat May 15, 2021 4:03 pm
That's what l was thinking of.. :D
drgeoff
Sat May 15, 2021 4:11 pm
I recall using a centrifuge in the school chemistry lab to move the goo around the germanium to the bottom of the glass envelope.
Also ISTR the RRP of an OC71 was 6 shillings and six pence whereas an OCP71 was in the region of four times that. Mid 1960s.
Quis custodiet ipsos custodes?
Sat May 15, 2021 4:19 pm
Oh boy. That brings back memories.
scruss
Sat May 15, 2021 4:27 pm
Yes: there's one quite like it on the Raspberry Pi Pico. They're pretty common on embedded boards: ESP8266 / ESP32 / STM32 / SAMD boards I use with MicroPython mostly use them. But they're most commonly known as BIOS chips, because so many PCs use Winbond 25Q32BVSIG to store their BIOS code.
They're Flash, though, not RAM. While I think you can access them like the simple older Microchip 8-pin SPI memory chips like the SST25 Flash and 23LC SRAM chips, they typically use Quad-SPI for higher speed. QSPI uses four data lines in parallel instead of just one in traditional SPI.
With extreme care :-) The light sensor is way too small for my old eyes. I can just manage SOT323 and SOIC, but I don't particularly enjoy it. There are SMD to DIP adapter boards which make things easier. The cheap SMD-DIP boards still require care, but there are really expensive ones that have individual tinned slots for each lead that help hold the part in place.
Pronouns: he/him
Gavinmc42
Sat May 15, 2021 11:09 pm
Not the smallest light sensor I have used..
Stereo microscope and extra lighting.
Done a few parts that needed max magnification.
Glue them deadbug and solder tiny wires to the bottom, now top pads.
6 hours for one part once.
Galden and a $9 stock pot on a heater, DIY vapour phase reflow.
90% did not solder properly, but I just needed 2 for prototyping.
Next time solder mask PCBs, not bare copper ;)
But it was a few hours and not days over a microscope.
Not sure how much longer I can work in this industry, parts are getting too small.
Lucky we have breakout PCB guys like Adafruit, Sparkfun and many more.
But sometimes smaller breakout boards are needed, then it becomes DIY.
HawaiianPi
Sun May 16, 2021 12:34 am
To me those look like parts that fell off of something, and those two larger pieces look like short strips from a parts reel used in automated manufacturing (those types of parts are not designed for hand soldering).
Did you order bulk parts (as opposed to a functional circuit board or breakoout board)?
cleverca22
Sun May 16, 2021 2:19 am
what all was in this order?
Return to “Off topic discussion”
