PeterO
Old fashioned fault finding....
Thu Jul 11, 2019 6:47 pm
Some may find this interesting :
https://www.tnmoc.org/notes-from-the-mu ... -the-diode
This is the machine that I emulate on my Pis so that I can develop software when I'm at home.
PeterO
drgeoff
Re: Old fashioned fault finding....
Thu Jul 11, 2019 7:25 pm
Very wise to replace both diodes. Until the mains fuse blew, the working diode would have been very stressed on alternate half cycles. Twice normal voltage and only the resistance of the transformer winding to limit the current.
PeterO
Thu Jul 11, 2019 7:39 pm
Yes, which I why I was surprised they didn't both go. I don't know which fuse went first so there is no way to tell what the actual conditions were until they had both gone, but to be honest I was more concerned about uneven load currents due to differences in the characteristics between diodes manufactured 50 years ago and modern ones.
PeterO
drgeoff
Thu Jul 11, 2019 7:53 pm
PeterO
There is no "uneven load currents". Both diodes are never conducting at the same time.
PeterO
Thu Jul 11, 2019 8:00 pm
Yeah, but they may have had uneven volt drops when conducting.
PeterO
Imperf3kt
Thu Jul 11, 2019 8:01 pm
The UPS consists of a 23Ah 26V Nickel Cadmium battery
When they were new a battery could power the computer for a few seconds, or with optional modifications to the power circuits for a minute or so.
That computer sounds like it uses a lot of electricity.
Time to replace it with a ~15W Raspberry Pi 4b?
55:55:44:44:4C
52:4C:52:42:41
drgeoff
Thu Jul 11, 2019 8:15 pm
PeterO
That wouldn't cause any problem. Compared to the 26 volts from the transformer any difference in diode voltage drop would have insignificant impact on the relative currents through the diodes.
drgeoff
Thu Jul 11, 2019 8:17 pm
@imperf3kt
You are showing your age. Or rather, lack of it. :)
https://en.wikipedia.org/wiki/Elliott_803
PeterO
Thu Jul 11, 2019 8:28 pm
PeterO
Transformer secondary voltage is nearer 60V peak at full load. The smoothing and regulation is not conventional for a low voltage high current supply by modern standards.
PeterO
Imperf3kt
@imperf3kt
Correct me if I'm wrong (likely), but 23Ah at 26v is 598watt hours of juice.
Used in "a few seconds"
I know old computers used a lot of power, but that's a LOT
55:55:44:44:4C
52:4C:52:42:41
PeterO
Thu Jul 11, 2019 8:32 pm
Read the article (especially note Fig. 14). The battery is only "on load" during a mains failure. In normal use the battery charger is providing 26V and 44A , that's the real consumption !
PeterO
drgeoff
Thu Jul 11, 2019 8:35 pm
PeterO
PeterO
So diode voltage mismatch is even more insignificant.
PeterO
Thu Jul 11, 2019 8:44 pm
PeterO
The documentation suggests that they were matched pairs. I bought four and chose the two with nearest volt drops.
Regulation is achieved with a "Transductor" in series with the transformer primary,
Anyway it doesn't really matter...
PeterO
Thu Jul 11, 2019 8:54 pm
They certainly did. One I worked on had a couple of ammeters on the wall which used to read around 100A at 208VAC when the computer was running. That was before we added another room full of disk cabinets.
There were a set of motor-generators in the basement to convert from our local 415VAC 50Hz to the 208VAC 60Hz that the computer needed.
Oh, and I helped dismantle another computer later where the 5V power connections were stainless steel bars about 30mm by 15mm section.
PeterO
Thu Jul 11, 2019 8:58 pm
We have to be a bit careful which machines we run together as we have caused fuses in the building substation to blow in the past ! I suspect they may have been a bit old but still....
PeterO
Imperf3kt
Thu Jul 11, 2019 9:25 pm
PeterO
So that comes out to 1144W, still a lot of power.
55:55:44:44:4C
52:4C:52:42:41
W. H. Heydt
Fri Jul 12, 2019 1:04 am
PeterO
Last I looked you could buy 1500W PSU for desktop PCs. They probably go higher by now.
It all kind of depends on what you're used to.... There was an MG set in the basement of the EE building at UC Berkeley where the DC output side was 1000v at 980A.
Imperf3kt
Fri Jul 12, 2019 1:47 am
True, but what does this system do that uses 1200W vs what does a 1500W desktop PC do?
Wikipedia claims it uses 3.5kw.
It's kind of like comparing a scientific calculator that runs on solar, and fits in your pocket, to a simple addition / multiplication calculator that runs on solar and is the size of a bus. One clearly does a lot more than the other in the same power budget.
Ultimately what I'm getting at is; why is such a system still in use when a Raspberry Pi is more than capable of emulating it?
55:55:44:44:4C
52:4C:52:42:41
PeterO
Fri Jul 12, 2019 5:27 am
Imperf3kt
Fri Jul 12, 2019 8:31 am
Wait, it's a museum piece?
What sort of programs do you make for that.
55:55:44:44:4C
52:4C:52:42:41
PeterO
Fri Jul 12, 2019 8:42 am
:roll:
All sorts... Lately I've been using it to create and draw mazes
https://www.youtube.com/watch?time_cont ... XaSCHJYJDw
PeterO
