RomoBoom
I have a problem with the sound on my pi-top.
Sat Sep 01, 2018 12:20 am
When i watch a video, like on YouTube, the music has very poor quality, and when someone speaks, i can hardly hear them. Even at full volume! :( can someone please help me?
pcmanbob
Re: I have a problem with the sound on my pi-top.
Sat Sep 01, 2018 3:41 pm
Hi.
Seeing as you have purchased a Commercial product based on the pi, you should really be ashing the makers of the product for support.
They have there own support and forum.
https://pi-top.com/support
https://support.pi-top.com/en/support/discussions
RomoBoom
Sat Sep 01, 2018 5:47 pm
But i am using a raspberry pi in my pi-top, because 'Ceed Universe' killed the SD card.
hortimech
Sat Sep 01, 2018 6:49 pm
Bit lost here, you say you are using a raspberry pi in your pi-top, what did you have in it before ? I thought it was designed the raspberry pi ?
By following the link above, I found out there seems to be a problem with the pi-top and sound, so If I can find this (and a possible fix), why can't you ?
Sat Sep 01, 2018 8:00 pm
Do you actually mean you are running Raspbian Stretch with Desktop OS ?
https://github.com/rricharz/pi-top-setu ... /README.md
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
RomoBoom
Sun Oct 07, 2018 5:27 am
Its about the SD card
a pi-top has a different pre-programmed SD card than a SD card for a raspberry pi
and no, i wasn't using desktop. its a python coded version of creed universe
LTolledo
Wed Oct 10, 2018 11:59 am
Ditch that "pre-programmed" microSD card, get a new one, about 16G to 32G, Class 10 or A1, and flash the latest raspbian stretch with desktop using Etcher.
once installation is all complete, then install the drivers for the sound card (I take it you're using a Pi-Top speaker module). Battery monitor is already included in the latest raspbian image, you just have to enable it at the panel.
if you are not using the Pi-Top speaker module and using the audio jack to output audio to a set of USB speakers, then just connect the speaker plug to to the audio jack. Make sure you select "Analog" as the audio output device.
I have a Pi-Top v1 with a battery in "coma" state, but that didnt deter me from still using the Pi-Top as always plugged in RPi-LapTop.
( RPi model used in Pi-Top is Raspberry Pi 3 Model B, in USB native boot)
Some people be like:
RomoBoom
Tue Oct 30, 2018 1:14 pm
i found out why the sound was horrible
its with the pitop hub(2.0) the sound plugin is DESTROYED
i think someone (probably my sister :lol: ) pulled the chord out way to hard and/or to fast :(
i've been using the SD card you suggested since "creed" killed the pi
Return to “Off topic discussion”
