adlambert
Wanted: Model B Rev. 1 V3
Tue Jan 01, 2013 12:57 pm
I am looking for a version of Model B Rev.1 Code 3 256MB Pi with D14 removed as in BOLD below:
Model and revision Code(s)
Model B Revision 1.0 2
Model B Revision 1.0 + ECN0001 (no fuses, D14 removed) 3
Model B Revision 2.0 4, 5, 6
Does anyone who is UK based have one of these that they would be prepared to exchange for a band new unused Rev 2 512MB Pi?
ShiftPlusOne
Re: Wanted: Model B Rev. 1 V3
Tue Jan 01, 2013 1:07 pm
Moved from general discussion.
audigex
Fri Jan 11, 2013 10:50 pm
Edit: Never mind, looks like I've got a chip marked D14 on the back of the board, so I've not got the version you want.
ShiftPlusOne
Fri Jan 11, 2013 10:58 pm
Look where the HDMI connector is. Check the other side of the board for D14. If you see D15 and D16, but D14 is removed, that's a sign. Now flip back to the proper side up and look in the corner between the audio jack and the usb ports. If there is no mounting hole and you have two devices marked with a '0', then it's the board he's after. Last check is to fire it up and run "cat /cpu/procinfo" the revision should say '0003'.
Cloudcentric
Fri Jan 11, 2013 11:00 pm
audigex wrote:Edit: Never mind, looks like I've got a chip marked D14 on the back of the board, so I've not got the version you want.
You can determine which board revision you have by typing cat /proc/cpuinfo at the command line and looking up the hardware revision code in the following table:
I have a Code 2, unfortunately
I know everything about nothing"
ShiftPlusOne
Fri Jan 11, 2013 11:22 pm
Someone on the IRC channel has a rev2 (512mb with mounting holes), but cpuinfo reports 0002. So I am actually not sure how reliable it is.
Patatra
Tue Jan 22, 2013 8:53 pm
I have the version you want (Model B, Rev. 1, Code 3 256MB, without D14).
You have to know the warranty bit is set, and I'm not in the UK but in France.
root ~ # cat /proc/cpuinfo
Processor	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: swp half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 1000003
Serial		: 00000000392*****
By the way, I'm not really interested in another Pi (already have a rev.2 512MB), but we may have another deal if you want.
1HzCoder
Mon Apr 22, 2013 2:13 am
I've got one, too bad I'm in the US. Didn't realize it was a rare one.
Good luck on your collection.
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
canibalimao
Mon Apr 22, 2013 4:46 pm
I don't know how I've only seen this now :?
I have a RPi in the specs you are asking, but, unfortunatly I'm in Portugal :(
BogoMIPS        : 464.48
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2708
Revision        : 1000003
Serial          : 000000008853faba
daveg
Mon Apr 22, 2013 5:26 pm
I can check which version my 256Meg pi is when I get home on Friday if you haven't found anyone with one to swap by then.
It's was going to be my mail server but can't run clamav and spamassassin in half a gig, so a swap for me would be ideal.
It also comes with vc1 and mpg codecs as its currently being used for openelec
phox
Tue Apr 23, 2013 4:47 pm
Sorry, got D14 on mine, it's a VERY first edition board, one of the first actually!
daveg
Sat Apr 27, 2013 11:10 am
sorry,
mine also has D14.
vwillcox
Tue May 14, 2013 8:15 pm
Mine has no D14 - but is not powered up.
I'll check the model - but got it late September last year so should be an earlier model (is 256mb ram)
EDIT - now powered on
root@MusicBox:~# cat /proc/cpuinfo
BogoMIPS        : 464.48
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2708
Revision        : 0003
Serial          : 0000000001fa******
Looks like I have what you need - I'm in the UK so post should be cheap!
Let me know if your still looking!
View my Raspberry Pi stuff: http://talktech.info/talk-tech/raspberry-pi/
Return to “Wanted”
