mikkelsonr
RPi, 26 pin GPIO and Mounting Holes
Tue Jan 29, 2019 11:44 pm
I am looking for an original Raspberry Pi Model B with 26 pin GPIO and the mounting holes. I have a Geekroo Fairywren and need a RPi that will fit it. I am in USA, so something available in the USA would be preferred, but not required.
Thanks, Rolf.
pcmanbob
Re: RPi, 26 pin GPIO and Mounting Holes
Wed Jan 30, 2019 10:01 am
Hi.
As the original pi with the 26 pin gpio is no long produced you are probably going to have to look to the second hand market.
Ebay normally has some listed but you could try other second hand sales sites too.
example
https://www.ebay.com/itm/Raspberry-Pi-M ... ondition=4
https://www.ebay.com/itm/RASPBERRY-PI-R ... ondition=4
Earlton2
Wed Jan 30, 2019 10:07 pm
Would it help to simply purchase a Pi-Zero sans pins and solder in the 26 you need?
Or purchase a 40-pin Pi and chop off the unwanted pins.
The Pi's don't care.
I often just solder in a 10-pin header on a Pi-zero. The top position (pin-1) gets you power, I2C and serial data which is sufficient for some of my circuits.
Best check the first 26-pins haven't changed around from then to now.
I thought the only change was the additional pins were on a separate connector on the back and are now on the front in-line with the original 26.
Imperf3kt
Wed Jan 30, 2019 10:26 pm
The original model b Pi uses different mounting holes, so no, the OP cannot do that.
Google is ubiquitous - Try it today, it's free!
https://opensource.com/life/16/10/how-ask-technical-questions
drgeoff
Wed Jan 30, 2019 11:20 pm
The very first RPis did not have mounting holes.
A couple of the GPIOs were changed as new models were introduced See diagrams at https://pimylifeup.com/raspberry-pi-gpio/.
rpiMike
Thu Jan 31, 2019 12:00 am
You could probably use a GPIO riser to lift the GPIO connection, then build a mounting hole adapter to convert old Pi1 mounting holes to latest model mounting holes.
Imperf3kt
Thu Jan 31, 2019 12:09 am
Then what is the purpose of the two holes in the 2011 RPI 1B board?
HawaiianPi
Thu Jan 31, 2019 12:38 am
My GF has one of the early 512K Raspberry Pi Model B Rev 2 boards. I can ask if she wants to let it go. Coincidentally, I was just messing with it and an old 3.5" PiTFT screen, so I know it still works.
Rev 2 is model on the right in this pic (has mounting holes).
We are in the USA (Oregon).
The very first revision did not have holes. The Rev 2 boards started that. See pic above.
DirkS
Thu Jan 31, 2019 10:01 am
The holes were introduced in the second incarnation of the Pi1B.
And they did not start life as mounting holes. They were used during production/testing.
hippy
Thu Jan 31, 2019 3:22 pm
https://www.raspberrypi.org/blog/upcomi ... d-revision
Two 2.5mm (drilled 2.9mm for M2.5 screw) non plated mounting holes have been provided to assist with ATE test mounting ...
Warning: If used to permanently mount the PCB – do not over tighten screws or drill out to fit larger screws, as this will lead to damage to the PCB.
So not really mounting holes, but can be used as such with care.
I believe the Pi B+ was the first board with proper mounting holes intended to be used as such.
Return to “Wanted”
