mg4345
Wanted: meter logger
Tue Jan 16, 2018 4:28 pm
Hi, I'd like to commission a project - but I'm not sure if these is even possible!
What I would like is a small unit that has the capability to record gas meter readings from a rotating dial type gas meter see attachment for typical gas meter.
The unit would have a camera that can be mounted facing the gas meter and be battery powered.
It would then take a photo every 5 minutes or so and save the photo with a time and date stamp.
the next best thing would be for the unit to be able to translate that photo into a csv file to save me having to go through it and turn the images into spreadhseet entries.
If someone can build and programme the unit I can build a housing.
Let me know if you have any questions - I'm UK (bristol) based.
gas meter.jpg (9.23 KiB) Viewed 1909 times
mrdebug
Re: Wanted: meter logger
Tue Feb 13, 2018 1:38 pm
Hi. It isn't so hard to do. Maybe it can takes 2 or 3 days, without the ocr and the csv file output.
I suggest you to take a photo and to try with a ocr software. If the software can recognise the number value it is possible to try with tesseract.
If you want you can contact me.
Regards.
www. ???
www. ???
GMT+1
Skype: mrdebug
scruss
Tue Feb 13, 2018 2:24 pm
This might be a good start: OpenCV practice: OCR for the electricity meter
Are you already using the rotating magnet pulse output from your meter? If that picture is your meter, looks like it's already spoken for
Return to “Wanted”
