Compute module mobo's
Posted: Fri Jun 23, 2017 6:05 pm
by Octradox
There doesn't seem to be a wide range of mobo's available to purchase online... But is there any cm3 mobo's with dual CSI cameras and integrated WiFi? Bonus points for if it also has relays attached but if not that's ok (GPIO pins needed)
If not... Where would be the best place to have one made? Cheap, but you know, actually decently made. As in I would pay more for something reliable.
Re: Compute module mobo's
Posted: Sun Jun 25, 2017 1:32 pm
by mikerr
A list of CM mobo's /carrier boards would be handy, so here goes:
- default rpi carrier board - COMPUTE MODULE IO BOARD V3 https://www.raspberrypi.org/products/co ... -board-v3/
2x CSI
2x DSI
GPIO
USB
HDMI
- WD Media stick http://wdlabs.wd.com/products/media-stick/
USB
HDMI
- WD sata to pi http://wdlabs.wd.com/products/sata-adapter-board/
2x USB
HDMI
SATA
- WD smart cable http://wdlabs.wd.com/products/smart-cable-module/
2x USB
Ethernet
- Slice - media player using CM https://shop.fiveninjas.com/ https://shop.pimoroni.com/products/slice-light-kit
2xUSB
Ethernet
HDMI
- there was OpenPi - though they went out of business
https://www.kickstarter.com/projects/wi ... makers-and
Gumstick have a make your own service ($2000 setup + around $40 per board)
but they also sell a few custom boards for single purchase from $19 :
- minimal CM flash carrier: https://store.gumstix.com/raspberry-pi- ... flash.html
USB
- IO board: https://store.gumstix.com/gumstix-pi-co ... board.html
1x CSI
1x DSI
GPIO
HDMI
- Network board https://store.gumstix.com/gumstix-pi-co ... ernet.html
2xUSB
Ethernet
Posted: Mon Jun 26, 2017 6:03 pm
by Octradox
mikerr wrote:A list of CM mobo's /carrier boards would be handy, so here goes:
- WD Media stick
- WD sata to pi
- WD smart cable
Gumstick have a make your own service and a few custom boards:
- IO board:
- with ethernet:
Thank you very much for that! I was hoping there existed a mobo with two camera CSI ports, but looks like I'll either have to make do without, build one myself, or pay gumstix.
Posted: Sun Dec 16, 2018 2:19 pm
by hasseb
Still one more custom board with two camera connectors can be found from here http://hasseb.fi/shop2/index.php?route= ... duct_id=57
