I would a few Pie Zeros.... 20$ maximun!
Posted: Thu May 11, 2017 10:56 pm
by DoomsDayArtist
I want to start a coding program for the disabled and am doing so on the cheap with minimum help as I go!
Re: I would a few Pie Zeros.... 20$ maximun!
Posted: Fri May 12, 2017 1:44 pm
by topguy
Is the word "buy" missing from your subject line ?
If you are willing to buy Pi0 for 20$ (assuming it was per unit ??)I would suggest buying Pi3 for 35$ instead. I dont know exactly what setup you want for a "coding program" but I feel you are going to spend more money on the extra hardware ( usb-hub, mini-hdmi adapter, network etc ) you need for the Pi0 than you will save compared to buying a much more flexible Pi3.
Posted: Fri May 12, 2017 1:57 pm
by fruitoftheloom
DoomsDayArtist wrote:I want to start a coding program for the disabled and am doing so on the cheap with minimum help as I go!
Use Raspberry Pi B+ http://www.alliedelec.com/raspberry-pi- ... /70377493/
Posted: Fri May 12, 2017 2:24 pm
by DoomsDayArtist
No I mean several used pi zeros for 20$... I don't mean 1 pi zero for 20$
Posted: Fri May 12, 2017 2:29 pm
by fruitoftheloom
DoomsDayArtist wrote:No I mean several used pi zeros for 20$... I don't mean 1 pi zero for 20$
Good luck with that mission :roll:
Posted: Fri May 12, 2017 4:42 pm
by Burngate
Since postal charges might eat up most of your $20 budget, it might be worth putting your location in your profile (from your seventh post I gather you're in Miami?)
You never know, you might get lucky - somebody in the next road might come knocking!
Posted: Fri May 12, 2017 4:45 pm
by stderr
So you are looking for three for $20 when the lowest cost with shipping when they are actually available is at least $10 each?
Posted: Fri May 12, 2017 9:05 pm
by DoomsDayArtist
I thought they originally went for five dollars?
Posted: Fri May 12, 2017 9:09 pm
by fruitoftheloom
DoomsDayArtist wrote:I thought they originally went for five dollars?
$5 plus local taxes & shipping, Raspberry Pi products are always sold this way :D
