liudr
Can someone recommend a pogo pin for rpi 0?
Tue Jul 12, 2016 3:52 pm
I've seen several rpi 0 USB hub designs with short pogo pins for contact. I'm interested in trying but don't know a good part number:
http://referencedesigner.com/blog/hubpi ... ctor/3017/
The pogo pins are very short. Hopefully someone has a part number. I've only seen much longer ones and they are very hard to solder (won't stay in one place):
https://www.adafruit.com/products/394
I've only made one device with the above long pins. Not much experience in shopping for the right ones. The long pins have large heads and they are too big for rpi 0's test points.
Any information is appreciated.
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
mahjongg
Re: Can someone recommend a pogo pin for rpi 0?
Thu Jul 14, 2016 6:09 pm
159 spring loaded contacts found; Take your pick.
http://nl.farnell.com/webapp/wcs/stores ... reId=10168
liudr
Thu Jul 14, 2016 8:27 pm
Thanks. I'll look through them. Just need really small ones so their "trunks" don't touch each other, as the two test points are close.
flatmax
Mon Nov 13, 2017 10:09 am
We were searching for something similar for the Pi 0. Couldn't find it, so we started a new product, it may be useful to you :
https://www.kickstarter.com/projects/12 ... ef=piforum
I have been using them for a while now to debug various audio cards and other items I am prototyping - it is great and keeps the addons clean - I find it easier to debug with these pogo clips.
Matt
Check the Ultra 2 sound card - use our shop instead of Amazon Europe (Amazon USA is live).
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
digger72
Sun Dec 30, 2018 9:46 pm
I am the creator of the Hubpixed the - USB Hub with Pogo Pins for Raspberry Pi Zero
http://referencedesigner.com/blog/hubpi ... ctor/6551/
For Pogo Pins the digikey Part Number is ED8183-ND ( Manufacturer Mill Max)
Return to “Wanted”
