Wanted: Cheap HDMI Monitor (solved)
Posted: Thu Sep 03, 2015 2:25 am
by gandalf
If anybody has a cheap HDMI monitor that he/she would be willing to sell for less than $40 please notify me. It should be at least 9" diagonal length. As long as it still works I don't care how used it is.
Re: Wanted: Cheap HDMI Monitor
Posted: Thu Sep 03, 2015 2:32 am
by AndyD
Hi Gandalf, it might be a good idea to let people know where you are in the world. You probably need to be reasonably specific, as postage could quickly eat into your $40 budget.
Posted: Thu Sep 03, 2015 4:54 am
by rpdom
You can often pick up old monitors with a DVI-D input (as well as the normal VGA) for very little (or even free, like both the ones I have). Then you just need a cheap (£1) HDMI to DVI cable. It won't do sound, but the picture will be perfect.
Posted: Thu Sep 03, 2015 5:17 am
by PiGraham
rpdom wrote:You can often pick up old monitors with a DVI-D input (as well as the normal VGA) for very little (or even free, like both the ones I have). Then you just need a cheap (£1) HDMI to DVI cable. It won't do sound, but the picture will be perfect.
I was going to suggest that. Note that you can get sound from the 3.5mm A/V jack on the Pi. VGA monitors are also an option with a cheap HDMI - VGA converter.
Posted: Thu Sep 03, 2015 10:52 pm
by gandalf
AndyD wrote:Hi Gandalf, it might be a good idea to let people know where you are in the world. You probably need to be reasonably specific, as postage could quickly eat into your $40 budget.
Good point. Sorry for that. I am in the U.S.A. Thanks for pointing that out @AndyD
Posted: Thu Sep 03, 2015 10:58 pm
by gandalf
PiGraham wrote:I was going to suggest that. Note that you can get sound from the 3.5mm A/V jack on the Pi. VGA monitors are also an option with a cheap HDMI - VGA converter.
Could you give me a link to an example one that you know would work? I know that a lot of them don't work for some reason which is what initially "scarred" me off. :(
Also, are the graphics basically as fast for DVI and VGA as they are for HDMI? I haven't tried any screens yet on my pi(use SSH and VNC) except for a GPIO touchscreen that is very slow and sometimes will not load certain graphical programs. I know HDMI is digital vs analog for VGA. I just don't want to shell out $40 bucks for something that's going to be annoying to use. ;)
Posted: Thu Sep 03, 2015 11:06 pm
by kusti8
Its best to get a DVI monitor. Those are digital, the only main difference being that it doesn't carry sound. Then any cheap cable will work.
But with the introduction of the B+ most VGA adapters, as long as they are not cables, will work.
Posted: Thu Sep 03, 2015 11:11 pm
by gandalf
Thanks so much!! That was very helpful! I never thought of that! I found one for $34 on ebay with a power cord!:):D:) Thanks so much! IDK how to put the solved flag on this question but you answered it!
Posted: Fri Sep 04, 2015 6:23 am
by rpdom
You edit your original post (the one at the top of the thread) and change the title to include "SOLVED" :)
DVI-D carries exactly the same video signals as HDMI, just with a different connector. It can't handle the higher resolutions, but neither can the monitors, so you don't need to worry about that. The quality is better than VGA.
Re: Wanted: Cheap HDMI Monitor (solved)
Posted: Fri Sep 04, 2015 12:41 pm
by gandalf
Duh! Thanks! Thats funny... I always thought of DVI as old technology...older than VGA and turned down my nose on it. Great news. Thanks all!!!:D
