gandalf
Wanted: Cheap HDMI Monitor (solved)
Thu Sep 03, 2015 2:25 am
If anybody has a cheap HDMI monitor that he/she would be willing to sell for less than $40 please notify me. It should be at least 9" diagonal length. As long as it still works I don't care how used it is.
AndyD
Re: Wanted: Cheap HDMI Monitor
Thu Sep 03, 2015 2:32 am
Hi Gandalf, it might be a good idea to let people know where you are in the world. You probably need to be reasonably specific, as postage could quickly eat into your $40 budget.
Thu Sep 03, 2015 4:54 am
You can often pick up old monitors with a DVI-D input (as well as the normal VGA) for very little (or even free, like both the ones I have). Then you just need a cheap (£1) HDMI to DVI cable. It won't do sound, but the picture will be perfect.
PiGraham
Thu Sep 03, 2015 5:17 am
rpdom wrote:You can often pick up old monitors with a DVI-D input (as well as the normal VGA) for very little (or even free, like both the ones I have). Then you just need a cheap (£1) HDMI to DVI cable. It won't do sound, but the picture will be perfect.
I was going to suggest that. Note that you can get sound from the 3.5mm A/V jack on the Pi. VGA monitors are also an option with a cheap HDMI - VGA converter.
gandalf
Thu Sep 03, 2015 10:52 pm
AndyD wrote:Hi Gandalf, it might be a good idea to let people know where you are in the world. You probably need to be reasonably specific, as postage could quickly eat into your $40 budget.
Good point. Sorry for that. I am in the U.S.A. Thanks for pointing that out @AndyD
gandalf
Thu Sep 03, 2015 10:58 pm
PiGraham wrote:I was going to suggest that. Note that you can get sound from the 3.5mm A/V jack on the Pi. VGA monitors are also an option with a cheap HDMI - VGA converter.
Could you give me a link to an example one that you know would work? I know that a lot of them don't work for some reason which is what initially "scarred" me off. :(
Also, are the graphics basically as fast for DVI and VGA as they are for HDMI? I haven't tried any screens yet on my pi(use SSH and VNC) except for a GPIO touchscreen that is very slow and sometimes will not load certain graphical programs. I know HDMI is digital vs analog for VGA. I just don't want to shell out $40 bucks for something that's going to be annoying to use. ;)
kusti8
Thu Sep 03, 2015 11:06 pm
Its best to get a DVI monitor. Those are digital, the only main difference being that it doesn't carry sound. Then any cheap cable will work.
But with the introduction of the B+ most VGA adapters, as long as they are not cables, will work.
gandalf
Thu Sep 03, 2015 11:11 pm
Thanks so much!! That was very helpful! I never thought of that! I found one for $34 on ebay with a power cord!:):D:) Thanks so much! IDK how to put the solved flag on this question but you answered it!
Fri Sep 04, 2015 6:23 am
You edit your original post (the one at the top of the thread) and change the title to include "SOLVED" :)
DVI-D carries exactly the same video signals as HDMI, just with a different connector. It can't handle the higher resolutions, but neither can the monitors, so you don't need to worry about that. The quality is better than VGA.
gandalf
Re: Wanted: Cheap HDMI Monitor (solved)
Fri Sep 04, 2015 12:41 pm
Duh! Thanks! Thats funny... I always thought of DVI as old technology...older than VGA and turned down my nose on it. Great news. Thanks all!!!:D
Return to “Wanted”
