BuildUp78
Engineering Project - Need Help
Tue Nov 12, 2019 3:02 am
OK here’s what I am looking for. A basic knob switch, 4 settings plus off/on switch.
Each setting would control a speed to make the light dim up, hold, dim down on a specific timed setting.
I'm hoping to hire a hobbiest or student wanting to learn
rpdom
Re: Engineering Project - Need Help
Tue Nov 12, 2019 9:04 am
A few more details are needed:
What sort of light - mains (110/230V) or low voltage?
Do you mean a physical switch or a virtual one controlled by mouse/keyboard/touchscreen?
Which model of Pi are you thinking of using?
This post might be better off in the "Wanted" section of the forums. If you'd like it moved (please don't just post a copy of it), just click the report post icon and select the option for "Wrong category". The moderators are always happy to move posts to the correct section.
amanda_j
Tue Nov 12, 2019 12:42 pm
hi @BuildUp78,
i have seen your requirement and can help you with the same.
please get in contact via email [email protected] to discuss this further in detail. Or skype me: live:amanda_17153.
awaiting your response.
regards,
Amanda
B.Goode
Tue Nov 12, 2019 1:37 pm
You will probably get responses from the 'usual suspects' who reply here to every opportunity: they may not match your criteria for a hobbyist or student. (And make your own assessment of their competence - the fact that they read this forum does not imply any endorsement of their abilities.)
rpiMike
Tue Nov 12, 2019 1:43 pm
Another 'usual suspect' here. I'm a freelance software developer specialising mainly in Raspberry Pi projects.
I would suggest an Arduino may be more appropriate for your project, contact me at:
B.Goode
Tue Nov 12, 2019 1:52 pm
But, in fairness, @rpiMike is a regular contributor to ongoing discussions in these forums, not just an anonymous entity with a csinlabs.com email address.
PiGraham
Tue Nov 12, 2019 2:03 pm
What sort of light?
What is the the dimmer for? Is it to mount in a wall on mains voltage lighting circuit?
It seems more like a custom light dimmer design than anything built around a maker single board computer.
Maybe you should be looking for professional electronics engineers.
drgeoff
Tue Nov 12, 2019 3:11 pm
I interpret that as "someone who will do it for a pittance or even nothing".
zwieblum
Tue Nov 12, 2019 3:15 pm
I think this is the idea :mrgreen:
Return to “Wanted”
