StephenSRL
Fingerprint Scanner - TTL (GT-511C3)
Tue Apr 08, 2014 7:52 pm
I would like someone to write the programming for the PI to preform the following functions:
Enroll Fingerprints
Identify Fingerprints and if accepted open a relay
Allow database to be extracted and added
codelectron
Re: Fingerprint Scanner - TTL (GT-511C3)
Sun Apr 20, 2014 1:40 pm
Hi StephenSRL,
I am interested in this project, Take a look at my website and drop me an email if you want to take this further.
www.codelectron.com
Greetings,
Krishna
www.codelectron.com
kishore
Sun Aug 31, 2014 4:19 am
how u connect the fingerprint scanner to raspberry pi?plz explain me about that to complete project.
jeanmachuca
Wed Nov 05, 2014 8:06 pm
Hi guys!
Now you can use this python driver for Sparkfun GT511C3 fingerprint connected to GPIO in raspberry pi
https://github.com/QuickGroup/pyGT511C3
sic
Tue Aug 11, 2015 3:23 am
jeanmachuca wrote:Hi guys!
Are there any updates with the github link for the python version? I had to do some modifications to fix the logic of LegacyEnrol and it still behaves differently. All the function except the verify, identify, and LegacyEnrol work well for me.
usamakhalid.92
Thu Jan 21, 2016 10:23 am
I have been trying to run GT511C3 module with raspberry pi 2 but it is not working at all. I have downloaded the library pyGT511C3 . It is not even turning on its LED. Has anybody done this? I need help.
gauravdave01
Sat Mar 19, 2016 7:36 am
Can you share, what changes you've made, to make it work.
myriadovi
Wed Sep 14, 2016 3:54 pm
Could someone please lay out all physical parts needed to be able to connect this to the actual Raspberry PI? I have the latest RPi model, but I don't know what else I need. Is a breakout board needed and/or USB to TTL board and proper wiring to be able to connect it?
myriadovi
Tue Sep 20, 2016 1:20 pm
Anyone?!
Douglas6
Tue Sep 20, 2016 2:34 pm
The Sparkfun GT511C3 seems to be a 3v3 compatible serial device. I'd say, to connect it, you'd need 4 wires (PWR, GND, RX, TX).
I'd recommend purchasing the JST-SH pigtail as mentioned in the product description.
myriadovi
Wed Sep 21, 2016 12:05 pm
Thanks a bunch! Cheers!
pooyan
Fri Apr 07, 2017 1:51 am
Hi, I'm using this fingerprint gt511C3 for a project working with
raspberry pi3 and python v2. I made the code to work to do the
enrollment successfully. but, when I ckeck to see if that id is
enrolled the results is false, and the number of enrolled ids is zero.
I appreciate it if you can help me.
pooyan
Fri Apr 14, 2017 3:11 am
hi, can anyone help me with (self.save) for Enroll3. the template can't be saved after 3rd enrollment.
cohen13
Sun Apr 23, 2017 10:26 pm
Would anyone have any code that works with a raspberry pi 3 for this FPS,
Any help would be much appreciated
Thank you
_farzanayusoff
Tue Apr 25, 2017 5:11 pm
there is a change that had been made by this guy. go check it. https://github.com/Jucker/SIPIntercom-with-FPS
if u mind can u share the code for the LegacyEnroll? i cant even make it enroll.
eeemizan
Wed Aug 23, 2017 9:08 am
I have done project by this Fingerprint Scanner - TTL (GT-511C3). Where university student is identify and show their all academic information and also update information by this scanner. also you wanted to use database it's easy if you want to can get everything from me.
piroteam
Thu Aug 31, 2017 9:05 am
Hi, everyone.
During my last project with fingerprint technology, I ended up with quite a few of these exact (GT-511C1R) sensors. They are all new, unused, in mint condition. Since my current project aren't within the fingerprint field, I'm willing to sell them to anyone who'd be interested in using them.
Shoot me a private message/email if you're interested.
Regards,
Matjaz
troyw
Tue Sep 05, 2017 1:33 pm
Enroll Fingerprints
I believe i can assist you for your requirements. Please drop me a message.
Troy
perumaluniversal
Fri Sep 22, 2017 7:15 am
I have created some java library for minimal communicate with GT-511C3 Fingerprint sensor. please get it from below GitHub URL. I think this will be useful for you while connecting GT-511C3 over USB To TTL Module in Raspberry PI Modal's.
https://github.com/perumaluniversal/FPS ... va-Library
code_core
Mon Oct 16, 2017 6:21 pm
Does anyone have Python3 code for this sparkfun fingerprint scanner. I am trying to get it to store all the fingerprint data on an sql database so anyone can sign in to the python app with their fingerprint regardless of which scanner they use (the scanners will be the same model). How would I do this?? :?:
Return to “Wanted”
Who is online
Users browsing this forum: No registered users and 2 guests
