Hey everyone,
I luckily received my pi yesterday. Everything I tried until now including XBMC worked fine.
I am trying to setup my USB peripherals but as soon as I plug in my powered USB hub, ethernet fails. dmesg shows hundreds of "eth0: event 4 may have been dropped". All USB devices are however discovered without errors.
I am quite sure that this is not a power-related issue because the devices aside from the hard disk are low-power devices. If I unplug the usb hard disk it still fails.
Edit: Ethernet even breaks if nothing is attached to the hub. The hub is a 7 port hub from Belkin - are these incompatible?
Edit2: It seems like my Pi does not like usb hubs at all. The other no-name brand hub I have lying around also breaks the network connection with no devices connected. Having the usb hub's power supply connected/disconnected does not make a difference either.
Any Ideas?
Attached to the usb hub are:
- wireless keyboard
- wireless mouse
- usb soundcard
- usb IR-receiver
