Anobium
Re: No sound via HDMI or 3mm
Sat May 05, 2012 10:54 am
I am using the Debian distribution.
Is sound working?
I have tried via the HDMI, 3mm sound port and a USB adapter.
Any pointers to resolving this issue?
Anobium
Sat May 05, 2012 11:05 am
A little more info.
I am trying to play Mp3 files.
I have 3 sound options, HDMI, 2mm port, and an USB adpator.  None currently work.
I have tried aplay, mplayer and LXmusic.
I have tried 'sudo modprobe snd_bcm2835' then retested.
I have change config.txt and added hdmi_drive=2
dom
Sat May 05, 2012 11:36 am
Try:
cd /opt/vc/src/hello_pi/hello_audio
make
./hello_audio.bin
to test analogue output. And
./hello_audio.bin 1
to test HDMI.
Anobium
Sat May 05, 2012 11:44 am
This test works fine... very loud.  Thank you.
Now, how do the same in LXMusic?
dom
Sat May 05, 2012 11:57 am
For me this works:
sudo aplay <name of wav file>
By default output will be automatic (hdmi if hdmi supports audio, otherwise analogue).
You can force it with:
sudo amixer cset numid=3 <n>
where n is 0=auto, 1=headphones, 2=hdmi.
However alsa driver is alpha quality, and has issues.
Anobium
and..
mplayer -ao sdl mymusicfile.mp3   works... a tad of stutter when moving mouse, but, still no sound in LXMusic.
Anobium
Sat May 05, 2012 12:29 pm
OK.  I am starting to understand.
sudo modprobe snd_bcm2835 ... before startx,
then, all works.  I missed that bit... new to this OS.
Still learning. I always will.
Thank you.
Tass
Sat May 05, 2012 10:37 pm
Thanks for the tips guys - I've got sound up and running over LXMusic now.  I'm looking to see if I can get sound working through Midori now - I want to listen to Indie Shuffle (www.indieshuffle.com).  Any pointers?
