clifmeister
Re: Keyboard layout (solved)
Fri Apr 27, 2012 4:11 pm
I was having trouble with the screen overscan in Debian Squeeze and while trying to fix it I discovered that my keyboard has a different layout than the system expects. I have a US keyboard, and it appears to expect the UK layout.
for example the number keys on my board when shifted should be:
but when I type them connected to my PI I get
So when I need " or # I can't seem to find them. Is there a way to change the keyboard layout to US?
Thanks,
Clif
shirro
Re: Keyboard layout
Fri Apr 27, 2012 4:54 pm
If you are not from the UK you might want to do some of the following:
Keyboard - look for the uk and change it to your type (us will do us, aus, can, nz etc). Then save and exit.
sudo nano /etc/default/keyboard
Locale - uncheck the uk and check the one you need and then set it as default. Mine is en_AU UTF-8
sudo dpkg-reconfigure locales
Timezone
sudo dpkg-reconfigure tzdata
Reboot to get the full effect.
clifmeister
Re: Keyboard layout
Fri Apr 27, 2012 7:01 pm
Thanks, that is exactly what I was looking for!
Clif
shirro
Re: Keyboard layout
Mon Apr 30, 2012 4:19 pm
Instead of the manual edit for keyboard this may be easier:
sudo dpkg-reconfigure keyboard-configuration
Poofjunior
Re: Keyboard layout
Wed May 16, 2012 6:59 am
Many Thanks! I've been able to adjust the layout to "us" qwerty settings as well.
One note though: rather than using the default keyboard (I can't remember which it was set to... ), I reconfigured my keyboard to an "apple" keyboard, and the Raspberry Pi now takes about five times as long to boot up.
Does anyone remember the default keyboard?
it's the underline in
XKBMODEL = "__________"
in the file located here: /etc/default/keyboard
RABIS50
Re: Keyboard layout
Wed May 16, 2012 1:41 pm
@ shirro
My questions is, do you have a list of allowed letters, especially for German (ge or de)?
RABIS50
logoff
Re: Keyboard layout
Fri Jun 01, 2012 3:48 pm
I think you should use "de" for german (deutsch).
For instance: "fr" for french, "es" for spanish, "it" for italian, "pt" for portuguese, and so...
rurwin
Re: Keyboard layout
Fri Jun 01, 2012 5:01 pm
It's the ISO country code, as distinct from the ISO language code. In some cases those are seen together separated by a hyphen. Hence en-GB or en-US. Most countries however are more boring, de-DE, es-ES etc. but some have surprises, for example ja-JP which appears to differ for no reason, since there is no jp language code or JA country code.
DarylMc
Re: Keyboard layout
Thu Jun 14, 2012 10:31 pm
There is a fix here
sudo setupcon
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=79249
anacron
Re: Keyboard layout
Tue Jul 10, 2012 10:25 am
manual editing didn't work for me, but
did work great!
 sudo dpkg-reconfigure console-setup
is also useful
rocketero
Re: Keyboard layout
Mon Jul 16, 2012 11:20 am
Poofjunior wrote:Many Thanks! I've been able to adjust the layout to "us" qwerty settings as well.
for US, PC keyboard:
and do changes to look like this:
XKBMODEL="pc104"
XKBLAYOUT="us"
save changes, then:
sudo setupcon
now try by pressing SHIFT+2 should give you @ (before with UK was ")
elenipapadimitriou
Re: Keyboard layout
Sun Feb 22, 2015 6:36 pm
hello,
I'm from Greece and I have a raspberry pi b+.I wanted to change my keyboard's language,I did change it to Greek and then reboot it. I couldn't login.Because my keyboard was writing only in Greek.My next step is to reinstalling the Operating System.Is there any other way to login without losing my data?Thank you.:)
wwwillem
Wed Oct 19, 2016 3:31 am
I followed what "rocketero" suggested, worked like a charm
in addition, it makes sense to update at the same time "/etc/default/locale"
change en_GB.UTF into for example en_US.UTF
after this change you should login/logout
check with the command "env | grep LANG"
adadion
Mon Dec 05, 2016 8:03 am
You can use simple command too
sudo setxkbmap us
to change to US layout, or change the 'us' to other locale.
