Hi
I am trying to setup a wifi link using the TP TL-WN722N as recommended on the e-Linux site. After a few problems caused by power supply to the adapter I have nearly succeded all apart form the last step of starting the Wlan interface. I can see wlan0 but when I run the command "sudo ifup wlan0" i get the message
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
I created the wpa.conf file as per the instructions (at http://elinux.org/RPi_Peripher.....ebian_6.29). It looks from some other websites and the debain site as though there should be a wpa_supplicant.conf file but I am way out of my depth on this. Has anyone else successfully setup wifi and did thay have a similar problem. Any clues as to how to fix this.
Many thanks,
Steve
