texy
'Nokia 3310' type LCD add on board
Sat Aug 18, 2012 3:56 pm
I have for sale a number of PCB mounted, PDC8544 based, 'Nokia' type LCD's completely assembled and with a 26-way ribbon cable.
It supports a 84 x 48 pixel resolution and is blue-LED backlit that is controllable via the GPIO PWM channel.
Python code can be found in this thread :
http://www.raspberrypi.org/phpBB3/viewt ... =32&t=9814
The price will be £10 plus postage, and 50p will be donated to the foundation for every sale.
PM me for further details and availability.
Texy
texy
Re: 'Nokia 3310' type LCD add on board
Sat Aug 18, 2012 5:36 pm
Additional information :
The ribbon cable is 100mm by default, but I will be building them to order, so other lengths are available.
Thanks,
Texy
gm1mqe
Mon Sep 03, 2012 2:15 pm
I would like one. I can Paypal or send a cheque.
Andy Norrie [email protected]
texy
Mon Sep 03, 2012 5:37 pm
Paypal is good for me - PM me your address. UK postage is £3.65.
Rgds,
Texy
gm1mqe
Mon Sep 03, 2012 6:07 pm
Silly question - how do I do a PM from the forum? Also what is your "address" on Paypal?
Cheers, Andy
texy
Mon Sep 03, 2012 6:10 pm
On the right, under my username ;-)
T.
thexman
Tue Sep 04, 2012 10:51 am
i have recieved my display PCB and Cable there a quaility product and its currently working on my Pi displaying its IP and so i an ssh into the Pi makes my life very easy now when i plug my Pi into some one elses Network . ill post the coding when i get the chance later.
one armed controls engineer, my grammar is bad but lets face it most keyboards don't suit a one armed man
gm1mqe
Sat Sep 08, 2012 2:10 pm
I ran your test program and the board worked perfectly. Lovely little board, thanks.
Andy
trickierstinky
Wed Sep 12, 2012 9:36 pm
I received these today and I am impressed!
Had some issues trying to get this setup and working (problems on my part), but when I got it working I used your script and it worked brilliantly.
Just need to learn python to get something meaningful in there :) any pointers.
But all in all well impressed with this little thing
DaveCummings
Wed Sep 19, 2012 8:20 pm
could you use this to show the system uptime & IP address? plus as a Debian user and somewhat noob how easy it it to get working?
dave
texy
Wed Sep 19, 2012 8:46 pm
Hi Dave,
At the end of the day, it is controlled by software. If you can integrate the control of the display via software of your choice, then it can do what you want. The software you use is the key......
T.
nhslzt
Mon Oct 01, 2012 8:52 pm
Received one today, very nice board! :)
battletux
Fri Oct 05, 2012 11:06 am
Texy, are you able to access the unused GPIO pins with this at all? And which pins are used for the screen?
Considering a screen for IP info on my dev Pi.
http://about.me/andy_mc
RaTTuS
Contact: Twitter YouTube
Fri Oct 05, 2012 11:17 am
ooh missed this .. pm sent
Covfefe
texy
Fri Oct 05, 2012 4:42 pm
battletux wrote:Texy, are you able to access the unused GPIO pins with this at all? And which pins are used for the screen?
Do you mean are the GPIO pins that are not used by the display available?
If so - yes they are. I included pads that are tracked to each of the GPIO connector pins, including power rails etc. I also included silk screening to label them, but i errrr ahem, made a mistake with those as i accidentally got the orientation wrong. However this is what the underside looks like :
..the centre pads are a repetition of the GPIO connections.
The Nokia LCD board uses the following GPIO pins :
BCM GPIO17 (pin 11) - Reset
BCM GPIO21 (pin 13) - SCE
BCM GPIO22 (pin 15) - DC
BCM GPIO18 (pin 12) - LED, PWM driven
BCM GPIO23 (pin 16) - DIN
BCM GPIO24 (pin 18) - SCLK
plus GND, 3v3, 5v
Hope this helps,
Texy
OS1
Sat Oct 13, 2012 12:41 pm
Hello Texy,
Do you have any of these boards left?
Thanks,
texy
Sat Oct 13, 2012 1:10 pm
Yes I have. Stocks are low, but more parts are on the way.
Texy
Damonsk
Mon Oct 22, 2012 10:01 pm
Hi I'm interested in one of these. You still have stock?
texy
Tue Oct 23, 2012 5:12 am
Yes I have. PM me your details.
Texy
funnybutrandom
Mon Oct 29, 2012 12:00 pm
Hey, do you still have any left? I'm interested in getting one
texy
Mon Oct 29, 2012 3:01 pm
Please PM me.
Texy
texy
Mon Oct 29, 2012 6:53 pm
please note the current shipment will have white backlite LED, not blue. I,ll post a picture shortly.
Cheers,
Texy
funnybutrandom
Thu Nov 08, 2012 3:41 pm
I don't seem to be able to PM :S, I must be missing something
texy
Thu Nov 08, 2012 3:50 pm
It's on the right, look under my location details.
Texy
thsBavR10
Thu Nov 08, 2012 4:12 pm
Hello Texy, do you have another one left?
I've sent you a PM.
Cheers Thomas
Return to “For sale”
