ags131
Armhf Ubuntu 14.04 Image
Fri Feb 13, 2015 4:21 am
I have successfully installed the Ubuntu 14.04 root fs tar (No Kernel) from armhf.com :)
It boots and seems to be working great, seems to be snappier than raspbian, although I haven't tried a comparison yet.
Required:
Latest Raspbian image
No-Kernel tar from here:
http://www.armhf.com/download/
install the raspbian image as usual
mount the second partition and copy the /lib/modules/* folder, this is needed for some usb devices
run mkfs.ext4 on the second partition
mount and cd into it
extract the tar from armhf.com
copy your /lib/modules backup
reboot and enjoy!
Note: the SSH service didn't seem to be enabled by default, I was at work so did a blind login via usb keyboard and `service ssh start`
rpdom
Re: Armhf Ubuntu 14.04 Image
Fri Feb 13, 2015 5:25 am
Don't you need to keep the /lib/modules/3.xx.xxx/* directories in order to have matching kernel modules?
I can see that the Pi will work without that, but many USB and other devices won't work without them
ags131
Tue Feb 17, 2015 6:45 pm
You will probably need to copy those over if needed, I haven't actually ran into any missing modules yet so didn't think of that. :)
Return to “Other”
