[Desktop Entry]
Type=Application
Exec=xscreensaver-pi-hdmi 1
Phil
[Desktop Entry]
Type=Application
I'm faced same issue. Xfce background gradient was terrible. Added true color settings to config.txt and fixed.livinitwarrior wrote:I might be missing something, but both in LXDE and KDE, the colors aren't blending correctly. It looks almost like old Win95 16-bit color schemes, and videos look horrible. Yet on Xbian and OpenElec, the HD looks great! Is there a special driver I'm missing? Because I know the raspberry can do better (it's a pi2), and nothing's showing up in "additional drivers"
Hi,ghostseven wrote:Playing with this now,
I have upped to to a webserver I run, so if people would like a HTTP download of it here it is: http://lagrange.ghost7.com/2015-02-07-raspuntu-tjc.zip
Can I suggest you try the latest version? It comes with a GUI desktop installed, which sounds like it'll be a lot easier for you to use than the command line, if you're new to Raspberry Pi.futura wrote:2015-02-07-raspuntu-tjc.zip
I am new to raspberry pi, any suggestions are appreciated. thx
network={
ssid="myssid"
psk="mykey"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
Running even better for me with the User Data and Cache directories moved to a (fast) USB flash drive - also saves wear on the MicroSD...cert wrote:florca: thank you, chromium 41 runs even better than firefox![]()
--user-data-dir="target" --disk-cache-dir="target"
Does it work if you download a copy of plain Raspbian on another SDCard and boot that?hdenie wrote:HELP I am new to linux
Downloaded and installed Linaro for Raspberry Pi 2 ( as per instructions)
I love the desktop presentation
inserted both mouse/keyboard dongle (works fine )
inserted wifi dongle, it is not recognized by wpa_gui (worked fine with Raspbian)
Inserted netwotk dongle, still no internet access.
Anybody could direct me into the right direction?
You can use sudo and I'm pretty sure it won't even ask you for a password. If it does, it's your account password.frwf73 wrote:I cant edit those files without knowing root password. Please provide it or tell me how to edit the configuration files.
ERROR: Unable to create Gui. Exiting
Error in '/usr/lib/xbmc/xbmc,bin"; corrupted double-linked list: 0x280a4d0
