florca
Re: Ubuntu / Linaro for Raspberry Pi 2
Fri Mar 27, 2015 8:54 pm
Contents of my LXDE ~/.config/autostart/.desktop (create one if it doesn't exist) is:
[Desktop Entry]
Type=Application
Exec=xscreensaver-pi-hdmi 1
Brgds
Phil
eriktheitalian
Fri Mar 27, 2015 9:50 pm
livinitwarrior wrote:I might be missing something, but both in LXDE and KDE, the colors aren't blending correctly. It looks almost like old Win95 16-bit color schemes, and videos look horrible. Yet on Xbian and OpenElec, the HD looks great! Is there a special driver I'm missing? Because I know the raspberry can do better (it's a pi2), and nothing's showing up in "additional drivers"
I'm faced same issue. Xfce background gradient was terrible. Added true color settings to config.txt and fixed.
( framebuffer_depth=32
framebuffer_ignore_alpha=1)
True color mode working like without problem.
But desktop gui performance not good like archlinux or raspbian.
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
cert
Fri Mar 27, 2015 11:33 pm
i'm trying to watch youtube videos with youtube-dl and omxplayer. i can log my last active tab in firefox with the firefox addon "URL logger" to ~/firefox-tab.log and then start a simple script/ command with
omxplayer $(youtube-dl -s -g $(cat ~/firefox-tabs.log))
now my youtube video runs smooth in fullscreen :D
XeoSal
Sat Mar 28, 2015 7:18 pm
Hello there, how can I install this beside raspbian? any help is appreciated. :)
futura
Sun Mar 29, 2015 6:04 pm
ghostseven wrote:Playing with this now,
I have upped to to a webserver I run, so if people would like a HTTP download of it here it is: http://lagrange.ghost7.com/2015-02-07-raspuntu-tjc.zip
I have downloaded this and write to my sd card and ran this on my pi, with no success with the user: linaro , password: linaro logging in.
From the first boot terminal screen:
linaro-developer:'# ( I type "login" )
linaro-developer:'# login (Then type linaro, pass word: linaro )
Than it takes me here:
* Documentation: http://www.linaro.org
[email protected]:s$ _
I am new to raspberry pi, any suggestions are appreciated. thx
florca
Sun Mar 29, 2015 8:15 pm
The default Firefox browser installed from this image seems fairly unstable, but upgrading to the version here:
http://launchpadlibrarian.net/200859811 ... _armhf.deb
and installing via dpkg -i provides a much more robust experience. Not sure there's any significant advantage over chromium, but maybe worth doing if you're a Firefox user.
Similarly you can retrieve and upgrade chromium (and the corresponding chromium-codecs-ffmpeg-extra ) to the latest version (41 as of now) from here:
https://launchpad.net/ubuntu/utopic/arm ... .10.1.1118
Brgds
Phil
LenReinhart
Sun Mar 29, 2015 10:44 pm
I did not realize the significance of Blender running on this image. Apparently it doesn't run on either Raspian or the Trusty Ubuntu image because the code they run is backward compatible with the original pi which is ARM6 architecture and the new Pi2 is ARM7. What is significant is that a full version of OpenGL is needed to run Blender and that is why it doesn't run on the old Pi, but it does run on the Pi2, with this image, so there must be a full version of OpenGL available for ARM7. One more reason not to maintain strict backward compatibility with the original pi.
wintrmute
Mon Mar 30, 2015 12:10 am
futura wrote:2015-02-07-raspuntu-tjc.zip
Can I suggest you try the latest version? It comes with a GUI desktop installed, which sounds like it'll be a lot easier for you to use than the command line, if you're new to Raspberry Pi.
cert
Tue Mar 31, 2015 2:01 pm
florca: thank you, chromium 41 runs even better than firefox ;)
is E19 enlightenment running on the rpi 2?
jaysongo
Tue Mar 31, 2015 4:00 pm
Hey all,
I've been trying to get this[1] to work. For the most part, I think it's good to go, but I'm having the hardest time getting the tiny Edimax EW 7811un wireless adapter to work. I know that this is not directly related to this thread - but was wondering if these newer updates to the image will potentially fix my issue.
If anyone's interested in helping me solve the driver issue, I would really appreciate the help.
Thanks,
jayson
cert
Tue Mar 31, 2015 9:51 pm
Jaysongo: edit /etc/wpa_supplicant/wpa_supplicant.conf and /etc/network/interfaces
wpa_supplicant.conf
network={
ssid="myssid"
psk="mykey"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
interfaces
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
this works with my RTL8188CUS
florca
Tue Mar 31, 2015 10:03 pm
cert wrote:florca: thank you, chromium 41 runs even better than firefox ;)
Running even better for me with the User Data and Cache directories moved to a (fast) USB flash drive - also saves wear on the MicroSD...
add
--user-data-dir="target" --disk-cache-dir="target"
to your /etc/chromium-browser/default Chromium config file (obviously change "target" to a USB drive mount point directory...)
Phil
rentay
Wed Apr 01, 2015 12:47 pm
Hey all
Congrats on a wonderful release. I have one question, how do I log in as syslog? What is the password?
I'm trying to set up qBittorrent and I'm having trouble running as root. Possibly this can solve my issue?
Cheers!
hdenie
Re: Ubuntu / Linaro for Raspberry Pi 2 No Internet access
Wed Apr 01, 2015 3:49 pm
HELP I am new to linux
Downloaded and installed Linaro for Raspberry Pi 2 ( as per instructions)
I love the desktop presentation
inserted both mouse/keyboard dongle (works fine )
inserted wifi dongle, it is not recognized by wpa_gui (worked fine with Raspbian)
Inserted netwotk dongle, still no internet access.
Anybody could direct me into the right direction?
Wed Apr 01, 2015 3:58 pm
hdenie wrote:HELP I am new to linux
Does it work if you download a copy of plain Raspbian on another SDCard and boot that?
What does an lsusb # ell, ess, you, ess, bee command show with the wifi plugged in?
This is a doctor free zone.
JeffZwolle
Wed Apr 01, 2015 8:34 pm
I am trying to run an OpenVPN server on this distribution, but am unable to.
I have tried it (Access Server) on Ubuntu 14.10 with a regular laptop (Intel) and it works fine there.
I have used http://www.huubmons.nl/multimedia/raspb ... pi-openvpn as my manual for install on my Rasperry Pi 2.
Am I missing something?
Any help would be appreciated.
Does anybody have a working install of OpenVPN the Linaro-image?
If so: Which manual did you follow and were there any exceptions?
markwwo4mw
Thu Apr 02, 2015 2:07 am
I have same issue getting an usb wifi dongle to be recognized by wlan0
lsusb returns
Bus 001 Device 005:ID 14b2:3c23 Ralink Technology, Corp. Airlink 101 AWLL6080 80 2.11bgn Wireless Adapter [Ralink RT2870]
I read about RT2800usb driver but packages found to put this on.
Nemesys
Thu Apr 02, 2015 12:32 pm
Some people have problems with wifi..
Please try this configuration:
Edit with root
and modify wlan0 to this:
allow-hotplug wlan0
auto wlan0
Edit with root
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=1000
update_config=1
Reboot.... and the wpa_gui work...
frwf73
Sun Apr 05, 2015 12:03 pm
I cant edit those files without knowing root password. Please provide it or tell me how to edit the configuration files. :oops:
kusti8
Sun Apr 05, 2015 4:52 pm
frwf73 wrote:I cant edit those files without knowing root password. Please provide it or tell me how to edit the configuration files. :oops:
You can use sudo and I'm pretty sure it won't even ask you for a password. If it does, it's your account password.
The linaro image is a little diy so at least for me I had to install wpa-supplicant and change interfaces and wpa_supplicant.conf.
frwf73
Sun Apr 05, 2015 8:48 pm
Thank you I used finally easy way by typing to xterminal "sudo leafpad" and then simply modified the configuration files. Now the wifi usb works great. :D
markwwo4mw
Tue Apr 07, 2015 4:24 am
Thanks. Work great for me. Sudo leafpad easiest way. Got TP-Link TLWN821N working great.
Now on to get ham radio programs working.
keyosuke
Wed Apr 08, 2015 12:33 am
It's been a while so I'm wondering if there are plans to keep working on this as a distro. It's been fun to play with.
pietrondo86
Wed Apr 08, 2015 3:01 pm
when i launch xbmx:
ERROR: Unable to create Gui. Exiting
Error in '/usr/lib/xbmc/xbmc,bin"; corrupted double-linked list: 0x280a4d0
valebat
Thu Apr 09, 2015 6:50 am
I've been looking at your "distro" for a couple of days. Great job on rolling this out.
I would like to extend the work you have done to include various embedded capabilities. Is the build environment you used available ? It would save me a lot of work and I'm willing post various upstream updates for others to use.
Return to “Other”
