nobe
Re: Ubuntu / Linaro for Raspberry Pi 2
Thu Feb 12, 2015 8:44 pm
hi guys,
i tried this image and it worked really easily.
There is something i don't understand though :
when i connect to the RPI2 through ssh and run the command :
sudo service lxdm stop
then the screen shows a console logged in with a root account, and i can't log off from it.
I also tried to boot in console mode by default
sudo cp /etc/X11/default-display-manager /etc/X11/default-display-manager.orig
sudo echo "/bin/true" > /etc/X11/default-display-manager
(btw, is there a better way to do that ? i didn't find any /etc/inittab file unfortunately...)
It also auto logged in with the root account.
how can i disable that "auto login to root" thing ?
ghostseven
Thu Feb 12, 2015 8:56 pm
nobe wrote:hi guys,
Doing the following will stop auto login (I personally hate auto login unless you have a media centre etc)
echo manual | sudo tee /etc/init/openvt.override
More info here http://superuser.com/questions/783560/l ... t-password
wintrmute
Fri Feb 13, 2015 2:05 am
nobe wrote: I also tried to boot in console mode by default ; how do I do that?
Disable the "lxdm" service from starting on boot -- try
echo "manual" > /etc/init/lxdm.override
wintrmute
Fri Feb 13, 2015 2:07 am
So, quick check to see what changes/features should be added to next version?
So far it'll include:
* Updated kernel
* Videocore libraries
* rpi-update
* possibly an auto-resizing-SD-card feature
Is there anything else handy I should throw in as well?
RobHenry
Fri Feb 13, 2015 2:24 am
wpagui would be a useful feature
ric96
Fri Feb 13, 2015 3:16 am
wintrmute wrote:So, quick check to see what changes/features should be added to next version?
* Updated kernel
* rpi-update
If possible the ability to upgrade without the need to reflash!
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: [email protected]
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
mw46d
Fri Feb 13, 2015 3:34 am
Hello, would you be willing to share your setup? I'm interested in Ubuntu on the Pi2 as well. But I would need Trusty/14.04.1 to play with ROS on it.
That would not be my first bigger build project;-) But I would prefer not to start all the way from zero.
Thanks,
-- mw46d
wintrmute
Fri Feb 13, 2015 3:53 am
Yeah, I'm sorry about that!
Once things have settled down, that should be the case - you'll be able to use regular Ubuntu package management to upgrade most things, and rpi-update to manage the others.
mikethebos1
Fri Feb 13, 2015 4:24 am
Some suggestions for the new build:
Modified rpi-config with overclocking, Autologin on/off, and keyboard config
Wifi config would be useful for non-geeks! :D Especially if your going to make it appeal to classrooms.
When will you be publishing a final build (production)?
Mike
Soeuni
Fri Feb 13, 2015 4:29 am
Hi. i Installed Ubuntu / Linaro for RPi2 very easily, but I cannot get any sound output.....
[email protected]:~$ alsamixer
cannot open mixer: No such file or directory
[email protected]:~$ aplay -l
aplay: device_list:268: no soundcards found...
what do i do? due to kernel options?
mikronauts
Fri Feb 13, 2015 5:44 am
I started a new thread to discuss Linaro vs Raspbian benchmark results... I ran a lot of benchmarks comparing the two.
Thread: http://www.raspberrypi.org/forums/viewt ... 63&t=99963
Thank you again wintrmute for your Pi2B Linaro image!
xEnt22
Fri Feb 13, 2015 7:50 am
nice a fellow aussie!
must say this boots faster, overall feels better and web browser is actually nice :D
please, pleasee add wpa-gui (and its associated libraries to run). my ethernet cables are too far away from my pi :(
Falken
Fri Feb 13, 2015 10:34 am
Great news and good work from wintrmute!!!! :P
How can I get to mount a pendrive? Actually, system doesn't do it...
Thanks in advance.
Regards
Rpi 2 and RS case
nobe
Fri Feb 13, 2015 11:00 am
first of all, thx to ghostseven and wintrmute for your tips :)
Soeuni wrote:Hi. i Installed Ubuntu / Linaro for RPi2 very easily, but I cannot get any sound output.....
the sound module isn't loaded by default
sudo su
modprobe snd_bcm2835
cp /etc/modules /etc/modules.orig
echo snd_bcm2835 >> /etc/modules
If your RPI2 is connected to a TV using HDMI, you might need to uncomment "hdmi_drive=2" in the /boot/config.txt file
mimi123
Fri Feb 13, 2015 11:38 am
And switch the default CPU governor to performance
snick
Fri Feb 13, 2015 1:45 pm
Hi there, just installed linaro on the Pi2 , having trouble getting it to recognise the KeySonic 2.4Ghz wireless keyboard/trackpad, that did work on Wheezy out of the box, any ideas where to go with this/what to install?
It has a USB dongle and the keyboard
Many thanks
jorgman
Fri Feb 13, 2015 2:49 pm
Hi, Wifi config would be really nice. For noobs like me it would be great.
Already lost my mind with trying to get it work yesterday....
SimonBlake
Fri Feb 13, 2015 4:37 pm
Just found this - it's looking great.
A couple of (possibly stupid) questions - how do I set the locale? I'm in the UK but I appear to have a US keyboard layout.
And, when I click Shutdown, I get GDBux.Error.org.freedesktop.DBus.Error.AccessDenied: Operation not permitted - so how should I shut it down (or am I doing something stupid?)
Simon
evaskp
Fri Feb 13, 2015 8:19 pm
sudo locale-gen sv_SE.UTF-8 thats for me in Sweden, for you in UK it would be en_EN.UTF-8
I have the same shutdown problem.
SimonBlake wrote:Just found this - it's looking great.
Simon
zproc
Sat Feb 14, 2015 12:41 am
Just installed this image. Seems more responsive at first already, nice.
What do i need to install on this (which packages?) to use my wifi dongle? There is not wpa_supplicant package in the repos apparently...?
Edit: Found the package under another name and installed wpagui.
But no module loads for each of my Wifi dongle. I tried googling "Linaro + name of the device" from lsusb, but i only find kernel sources for odroids...
zlot
Sat Feb 14, 2015 4:41 am
As has been stated: "Awesome!"
Thanks so much.
The video in Rasbuntu is overshooting my monitor, though, and I can't shrink it or otherwise adjust the monitor. The margin adjustments don't bring in the bottom toolbar, which is really the crux of the issue.
Any suggestions?
Thanks!
xEnt22
Sat Feb 14, 2015 7:11 am
can you remove that screensaver program? its very outdated and has an annoying popup :P
also linaro does not have permissions to restart the computer.
and any chance of ubuntu software center being added? i apt-getted it, works great but must run it with sudo each time.
PateDeGato
Sat Feb 14, 2015 10:09 am
Hi.
I tried to install Unity using the linaro-ubuntu-desktop metapackage and gdm via Synaptic. I had to set lightdm as default because with gdm I only got a black screen.
If I try to login into Ubuntu Desktop, I just got a blank screen with a cursor.
¿Any idea about fixing it?
La selva es responsable de más de 3000 muertes por ataques de animales salvajes al año. Tiene más de 700 elementos que producen cáncer. Eliminemos la selva antes de que sea demasiado tarde.
berrabongo
Sat Feb 14, 2015 10:47 am
Hi ! Thanks for a great image. I'am trying to move progs from my old
RPI with a usb memory. I can see the memory in pcmanfm on RPi 2,
but Not authorized to perform operation. How do i set permissions? /Rune
mohog
Sat Feb 14, 2015 4:44 pm
Thank you for making this work.
Trying to figure out how to auto launch a chromium app/extension upon log in but can not seem to find a way to do so. Any ideas?
Return to “Other”
