pejase
ThinLink OS (based on Fedora 8)
Thu Nov 14, 2013 4:14 pm
Hi!
I've been using my Raspberry Pi some time now - but only with the NOOB Software!
I'm more of a user then a technican when it comes to Linux as well as programing.
I'm interested in to know if it's possible to get the ThinLink OS (TLCOS) to work on a Raspberry Pi,
but there is only a TLCOS-ISO installer file availeble. http://www.cendio.com/downloads/TLCOS-4.1.1.iso
This TLCOS-ISO is a ThinClient Software.
Looking forward to any reply.
Regards
//Peter
MoosePi
Re: ThinLink OS (based on Fedora 8)
Thu Nov 14, 2013 9:28 pm
The Raspberry Pi is based on the ARMv6 archetecture, it looks like TLOS is only available for Intel x86 architecture which is completely different
http://www.cendio.com/downloads/clientos.xhtml
Maybe you could find out whether other RDP software can be used to communicate with the ThinLinc Linux Remote Desktop Server ?
http://www.cendio.com/products/thinlinc
Pi Forum Search and Google yields answers to many questions
pejase
Thu Nov 14, 2013 10:52 pm
Thanks for your reply MoosePi!
I hope that you would help me with a reply to the follwing.
The TLCOS is based on Fedora 8 with Xfce desktop, but unforturnately I don't know what RDP Software it uses, however would you say that this release (http://fedoraproject.org/sv/get-fedora- ... 2nd_arches) might be possible to configure and load on to a Raspberry Pi?
Any reply would be most valuable!
Regards
//Peter
Regards
//Peter
MoosePi
Thu Nov 14, 2013 11:27 pm
pejase wrote:Thanks for your reply MoosePi!
Regards
//Peter
Unfortunately not wrong architecture, the only equivalent version of Fedora for the Raspberry Pi ARMv6 architecture is called Pidora, presently at version 18 which is one version behind Fedora:
http://pidora.ca
pejase
Fri Nov 15, 2013 4:23 pm
Thanks again MoosePi!
I'll check that out for a try :)
Kind regards
// Peter
Regards
//Peter
jhelling
Sun Mar 02, 2014 9:19 am
Thinlinc foresees in html5 compatibility via a web browser.
This is ... from a certain version of browser and upwards.
Typically in a small installation simply connect to the thinlinc server at port 300.
If the PI supports one of those browsers I guess your problem is rather well solved with a minimum of effort.
https://www.cendio.com/products/thinlin ... tml5.xhtml
You have to verify though if the connection via web is by default enabled ... don't know anymore if I had to enable that feature. But it works like a charm! The latency in display is low. Have to say though that I have not yet used it for video streaming (youtube things) as I use it for less media purposes.
If you want to go public, look in the administartion guide for a correct setup via vpn or other
Hopes this helps.
Would you be so gentle and kind to feedback if this works, please.
I'd like start pi-ing just as this would be one of the good reasons. I could replace/elaborate in an easy way sunray installations ...
Greetings,
Jan.
Return to “Other”
