mushroom glue
BerryBoot remote login
Wed Feb 27, 2013 9:16 pm
Hi. I've been trying to setup a raspberry pi headless using Berryboot. I've followed the instructions to setup the VNC server, however when I try and login using tightVNC, it says that connections have been actively refused. It's a free IP adress, and I've pinged it and it responds. The slight difference between this and a normal network setup is that it's connecting through my PC's network card, but this worked OK in a previous installation. Anyone any ideas?
hacktrix2006
Re: BerryBoot remote login
Mon Jun 17, 2013 12:46 am
Insert your SDCard into your Windows/Linux/Mac OSX PC/Laptop and look for a file called cmdline.txt. Open that file and add the following line.
For ethernet use:
vncinstall ipv4=(IP)/(NETMASK)/(GATEWAY)
for example
vncinstall ipv4=192.168.0.1/255.255.255.0/192.168.0.254
for Wireless its the same but with a ending like this
vncinstall ipv4=(IP)/(NETMASK)/(GATEWAY)/wlan0
for example
vncinstall ipv4=192.168.0.1/255.255.255.0/192.168.0.254/wlan0
After you have added that line simply save and insert the SDCard back into the and reboot.
Its also a good bet to set in cmdline.txt bootmenutimeout=10 to something like 30 to insure you connect in time.
christurnerchris
Sun Jan 24, 2016 2:53 pm
I am using ultravnc - what do you put in to the questions
host name
Connection #
darwyn001
Mon Aug 08, 2016 8:08 pm
I have a problem, I can not connect my BerryBoot through VNC, the ip is assigned correctly, the problem is that when entering the ip VNC, tells me that the connection was refused :?: :?: :?: :?:
MrCaringi
Fri Jul 13, 2018 7:05 pm
I have the sam problem, no SHH nor VNC ... someone figured it out?
Return to “Other”
Who is online
Users browsing this forum: No registered users and 3 guests
