charlieb000
Bare SBC (no OS, just your program)
Tue Feb 26, 2013 12:05 pm
I am curious to ask if there is an option for a "bare" OS, I am alluding to the competition like audino where there is little else but what is needed to flash itself. I do acknowledge that it would probably mean forfeiting many of the peripherals, but perhaps the manufacturer could have the video (as an example) respond to having the program (which i guess would nearly be called the OS) write some text to the screen, the BIOS accepting the command. I had this thought after i read that your program could be momentarily interrupted if the OS decides to do some background task. Being a fast processor it's probably not a super necessity unless you have some real intense process, but there could be a niche demand, so I ask. It may be just a bios upgrade.
It could be a requirement to use some of the peripherals, it would mean that code may need to be written from the coder, for example to reacquire an IP if connection were lost, but the tasks could be prioritised.
Charlie.
Cloudcentric
Re: Bare SBC (no OS, just your program)
Tue Feb 26, 2013 4:35 pm
The Raspberry Pi does not have a BIOS !
I know everything about nothing"
socialdefect
Tue Feb 26, 2013 8:58 pm
The Moebius project focusses on providing a 'bare bones' solution for the Raspberry Pi. It's based-on Raspbian packages and only includes the bare minimal OS features and a package manager that makes it easy to extend the basic system when required. Such a system runs all scripts that can be interpreted by the Linux shell and you can compile your own code to run.
http://moebiuslinux.sourceforge.net
== If it's not broke... I'm not done fixing it! ==
[email protected]
Tue Feb 26, 2013 9:07 pm
socialdefect wrote:The Moebius project focusses on providing a 'bare bones' solution for the Raspberry Pi. It's based-on Raspbian packages and only includes the bare minimal OS features and a package manager that makes it easy to extend the basic system when required. Such a system runs all scripts that can be interpreted by the Linux shell and you can compile your own code to run.
Except that @charlieb000 above didn't want an OS ...
-Gordon
Gordons projects: https://projects.drogon.net/
DexOS
Wed Feb 27, 2013 2:23 am
There are may example of using bare metal, alot with function not unlike the BIOS functions.
Example bare metal code to print string
include 'DexBasic\DexBasic.inc'
print "Hello World!"
sync
end
align 4
ProgramSize:
ScreenBuffer:
Display a image
load   MyBmpImage, ScreenBuffer
sync
end
align 4
MyBmpImage:
file 'Images\Bg.bmp'
align 4
ProgramSize:
ScreenBuffer:
Flash a led
pinMode  GPIO16, OUTPUT
LetsLoop:
digitalWrite  GPIO16, HIGH
delayMicroseconds  1000000
digitalWrite  GPIO16, LOW
goto  LetsLoop
align 4
ProgramSize:
ScreenBuffer:
HowTo here:
http://www.dex-os.com/DexBasic/DexBasic.htm
Batteries not included, Some assembly required.
JoeStrout
Thu Mar 06, 2014 11:32 pm
For bare-metal coding, I think Alex Chadwell's tutorials may be very helpful. Although it talks about creating an "OS," it's really just about putting code directly on the metal, with no other OS in the way.
http://www.cl.cam.ac.uk/projects/raspbe ... index.html
I just discovered this today, and I can't wait to try it myself!
Cheers,
- Joe
Fri Mar 07, 2014 9:40 am
JoeStrout wrote:For bare-metal coding, I think Alex Chadwell's tutorials may be very helpful. Although it talks about creating an "OS," it's really just about putting code directly on the metal, with no other OS in the way.
Cheers,
- Joe
You win this weeks thread necro prize! (although your link is indeed useful!)
Return to “Other”
