I'm trying to install a Debian (DietPi) onto it but it always fails.
I don't have a keyboard and external monitor, so I choose a headless install with predefined wifi key and SSID.
The problem is absolutely wierd (wlan0 interface works for sure, because that's the only way now to reach it via SSH and it works):
Pinging an IP address works:
root@DietPi:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=53 time=9.95 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=53 time=13.0 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=53 time=12.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=53 time=15.0 ms
^C
--- 8.8.8.8 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 7ms
rtt min/avg/max/mdev = 9.949/12.523/15.039/1.829 ms
root@DietPi:~# ping google.com
PING google.com (172.217.19.174) 56(84) bytes of data.
64 bytes from zrh04s07-in-f14.1e100.net (172.217.19.174): icmp_seq=1 ttl=53 time=10.1 ms
64 bytes from zrh04s07-in-f14.1e100.net (172.217.19.174): icmp_seq=2 ttl=53 time=12.7 ms
64 bytes from zrh04s07-in-f14.1e100.net (172.217.19.174): icmp_seq=3 ttl=53 time=12.9 ms
64 bytes from zrh04s07-in-f14.1e100.net (172.217.19.174): icmp_seq=4 ttl=53 time=13.2 ms
^C
--- google.com ping statistics ---
rtt min/avg/max/mdev = 10.102/12.236/13.163/1.248 ms
root@DietPi:~# wget http://archive.raspberrypi.org/debian/dists/buster/InRelease
--2020-04-24 07:49:31-- http://archive.raspberrypi.org/debian/dists/buster/InRelease
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.86, 46.235.231.151, 46.235.230.122, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.86|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 25112 (25K)
Saving to: ‘InRelease.1’
InRelease.1 100%
[========================================================================================================================================>] 24.52K --.-KB/s in 0.1s
2020-04-24 07:49:32 (174 KB/s) - ‘InRelease.1’ saved [25112/25112]
Okay, now problem: let's download the same file from https:
root@DietPi:~# wget https://archive.raspberrypi.org/debian/dists/buster/InRelease
--2020-04-24 07:49:37-- https://archive.raspberrypi.org/debian/dists/buster/InRelease
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 93.93.135.117, 176.126.240.167, 46.235.231.111, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|93.93.135.117|:443... connected.
I did one more step:
root@DietPi:~# wget -d https://archive.raspberrypi.org/debian/dists/buster/InRelease
DEBUG output created by Wget 1.20.1 on linux-gnueabihf.
Reading HSTS entries from /root/.wget-hsts
URI encoding = ‘UTF-8’
Converted file name 'InRelease' (UTF-8) -> 'InRelease' (UTF-8)
--2020-04-24 07:52:26-- https://archive.raspberrypi.org/debian/dists/buster/InRelease
Certificates loaded: 128
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 176.126.240.86, 93.93.135.117, 176.126.240.167, ...
Caching archive.raspberrypi.org => 176.126.240.86 93.93.135.117 176.126.240.167 46.235.231.111 93.93.135.118 46.235.227.39 176.126.240.84 46.235.231.145 46.235.230.122 46.235.231.151 2a00:1098:88:26::1 2a00:1098:88:26::1:1 2a00:1098:84:1e0::1 2a00:1098:82:47::1:1 2a00:1098:80:56::2:1 2a00:1098:88:26::2:1 2a00:1098:84:1e0::2 2a00:1098:80:56::1:1 2a00:1098:84:1e0::3 2a00:1098:82:47::1
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.86|:443... connected.
Created socket 3.
Releasing 0x00f0a8d0 (new refcount 1).
GnuTLS: Error in the pull function.
Closed fd 3
Unable to establish SSL connection.
root@DietPi:~#
Trying this on another PI (at different location) works without issues.
Trying this from the same internet connection (same location) where the PiZero is works also.
