GUI inside Debian chroot environment doesn't work [dietpi]
Posted: Sun Oct 06, 2019 10:20 am
by WDHBGS
In order to use x86 applications on a Pi with DietPi as OS, I followed this tutorial: https://www.novaspirit.com/2019/04/15/run-x86-arm/.
Everything is working pretty well, although one thing isn't unfortunately. Whenever I try to run a GUI application in the Debian x86 chroot environment, the application won't run due to a display error. It seems it can't connect to the X server. I installed the standard Raspbian GUI (including the X server) and a VNC server in order to use a desktop environment (XFC and some other packages, https://raspberrypi.stackexchange.com/q ... bian-pixel). It's able to run every GUI application I want, except for those within the Debian x86 chroot environment. Every DISPLAY variable I tried so far, doesn't work. According to the tutorial, I have to use
export DISPLAY=:01
for a normal user and
export DISPLAY=:0
for the root user, but they aren't working. Even if I set the variable to the same value as the DISPLAY-variable in the 'non-chroot' environment, it won't work. For example, when I try to run winecfg inside the chroot environment, then it'll give an error that no window could be created due to a display error.
What can I try in order to fix it?
Thank you in advance!
WDHBGS
Re: GUI inside Debian chroot environment doesn't work [dietpi]
Posted: Sun Oct 06, 2019 9:24 pm
by topguy
export DISPLAY=:01
I have used
export DISPLAY=:0.1
or
export DISPLAY=:1
Showing us the *exact* error message could be useful.
Posted: Sun Oct 06, 2019 11:22 pm
by sakaki
Have you ensured that the ~/.Xauthority file from the host OS is either bind-mounted or copied into your chroot environment?
Best, sakaki
Posted: Sun Oct 13, 2019 8:53 am
by WDHBGS
Thanks for the responses.
I managed to fix it myself, I found out I just had to set the DISPLAY variable inside the chroot environment to the same value that the DISPLAY variable outside the environment has, which seems very logical. So it was a pretty easy fix in the end.
