Calabrone
How to get Temperature - [SOLVED]
Mon Aug 19, 2019 1:33 pm
Hi there. I've an Rpi4 using with OMV as a NAS.
I'd like to monitor the temperature and adjust the fan speed: but i don't know how to read the CPU temperature.
I'm using the distro provided by OpenMediaVault and i've seen there's the possibility to get CPU temperature from armbian-config or when i login to Rpi.
How can i get that temperature?
Thank you in advance.
RaTTuS
Re: How to get Temperature
Mon Aug 19, 2019 1:40 pm
vcgencmd measure_temp
also
possibly
check out
cat .bashrc
[it may work]
Covfefe
neilgl
Mon Aug 19, 2019 1:41 pm
Does this work from the command line when you are logged in?
Calabrone
Mon Aug 19, 2019 4:34 pm
I've already tried that command, but the lib vcgencmd seems not available.
vcgencmd: command not found
B.Goode
Mon Aug 19, 2019 4:39 pm
Perhaps you should be seeking advice from whoever builds/maintains/distributes that third-party Operating System?
danjperron
Mon Aug 19, 2019 5:25 pm
The welcome scripts are in /etc/update-motd.d
Check the script "30-sysinfo".
function getboardtemp() {
        if [ -f /etc/armbianmonitor/datasources/soctemp ]; then
                read raw_temp </etc/armbianmonitor/datasources/soctemp 2>/dev/null
                if [ ! -z $(echo "$raw_temp" | grep -o "^[1-9][0-9]*\.\?[0-9]*$") ] && (( $(echo "${raw_temp} < 200" |bc -l) )); then
                        # Allwinner legacy kernels output degree C
                        board_temp=${raw_temp}
                else
                        # Marvell gets special treatment for whatever reasons
                        grep -qi Marvell /proc/cpuinfo && \
                                board_temp=$(( $(awk '{printf("%d",$1/1000)}' <<<${raw_temp}) - 20 )) || \
                                board_temp=$(awk '{printf("%d",$1/1000)}' <<<${raw_temp})
                fi
        elif [ -f /etc/armbianmonitor/datasources/pmictemp ]; then
                # fallback to PMIC temperature
                board_temp=$(awk '{printf("%d",$1/1000)}' </etc/armbianmonitor/datasources/pmictemp)
        fi
} # getboardtemp
Try manually to figure out which line hold the correct temperature.
Calabrone
Mon Aug 19, 2019 9:40 pm
Thank you very much! The temperature is stored in /etc/armbianmonitor/datasources/soctemp file.
Return to “Other”
