dindibo4
can't open wireshark on kali RPI
Fri Aug 16, 2019 10:48 am
Hello, I have installed kali on my Raspberry Pi 3 B+ and it works great, the only problem is when I try to open wireshark through vnc, it won't open.
This is the output of the command:
[email protected]:~/Desktop# wireshark
Qt: XKEYBOARD extension not present on the X server.
Gdk-Message: 10:46:44.736: wireshark: Fatal IO error 2 (No such file or directory) on X server :1.0.
Does anyone know what's causing this problem?
B.Goode
Re: can't open wireshark on kali RPI
Fri Aug 16, 2019 10:51 am
An alternative source of advice: https://forums.kali.org/
drgeoff
Questions about Kali are best asked on Kali's own forum.
dindibo4
Fri Aug 16, 2019 10:54 am
I'll try to ask there, although I don't think it's distribution related.
B.Goode
Fri Aug 16, 2019 11:02 am
So have you confirmed this by replicating the issue while running the Raspberry Pi supported Raspbian Operating System?
dindibo4
Fri Aug 16, 2019 11:12 am
No, but it seems to be a problem with qt since wireshark has GUI
mahjongg
Fri Aug 16, 2019 9:30 pm
Anything using kali should be posted in OTHER OS
moved.
"seems" isn't good enough....
jj_0
Fri Aug 16, 2019 9:52 pm
It might be an issue with the capabilities of the vnc server. A similar issue is described and reolved
here.
Return to “Other”
