taylorkh
Upgrade ussue Ubuntu Mate 18.04 on Pi 3B+
Fri Aug 02, 2019 4:05 pm
I am getting this error on 3 of 3 Pi 3B+ computers so I suspect it is a bigger picture issue rather than my systems:
[email protected]:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  linux-firmware-raspi2
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 0 B/3,612 kB of archives.
After this operation, 35.8 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 145272 files and directories currently installed.)
Preparing to unpack .../linux-firmware-raspi2_1.20190215-0ubuntu0.18.04.1_armhf.deb ...
Unpacking linux-firmware-raspi2 (1.20190215-0ubuntu0.18.04.1) over (1.20180919-0ubuntu0.18.04.2) ...
dpkg: error processing archive /var/cache/apt/archives/linux-firmware-raspi2_1.20190215-0ubuntu0.18.04.1_armhf.deb (--unpack):
 trying to overwrite '/lib/firmware/brcm/BCM43430A1.hcd', which is also in package bluez-firmware 1.2-4+rpt1~bionic1.0
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
E: Sub-process /usr/bin/dpkg returned an error code (1)
Does anyone have any information or perhaps a work around?
TIA,
Ken
Re: Upgrade ussue Ubuntu Mate 18.04 on Pi 3B+
Fri Aug 02, 2019 5:01 pm
TIA,
Ken
Have you asked the developers for help ?
https://ubuntu-mate.org/raspberry-pi/
adieu
taylorkh
Fri Aug 02, 2019 9:46 pm
Yes. I am looking at some replies over there.
bjtheone
Sat Aug 03, 2019 4:16 pm
The issue is that you have a conflict between linux-firmware-raspi2 and bluez-firmware 1.2-4+rpt1~bionic1.0.
The "bluez" package is for Bluetooth dongles based on the Broadcom BCM203x chipset. I don't use bluetooth on my PI 3b+ and forced the install. Does not seem to have any disastrous results.
If you want to override it, you can do force the install via:
sudo dpkg -i --force-overwrite <filename>
which will be
sudo dpkg -i --force-overwrite /var/cache/apt/archives/linux-firmware-raspi2_1.20190215-0ubuntu0.18.04.1_armhf.deb
and then
sudo apt-get -f install
taylorkh
Sun Aug 04, 2019 2:33 pm
Thanks bjtheone
I am seeing similar answers here https://ubuntu-mate.community/t/error-u ... 3b/20001/7
Ken
Return to “Other”
