RPIgoodSBC
Kali linux on rpi4
Sun Jul 14, 2019 2:44 pm
Kali linux on rpi4 2Gb RAM...
Using Sandisk A1 16Gb SD card.
https://www.offensive-security.com/kali ... rm-images/
https://images.offensive-security.com/a ... mon.img.xz
Recomended using etcher to make the bootable SD card and wait up to 5 minutes on the first boot.
The first boot is slow.If the rpi is not responding, reboot (Ctrl+Alt+Del) and after reboot you go to screen user and password.
Default user is root
Default password is toor
Minimal configuration...
dpkg-reconfigure keyboard-configuration
dpkg-reconfigure tzdata
reboot
apt-get update
apt-get dist-upgrade
apt-get autoremove
Some software...
apt-get install gnome-screenshot vlc chromium smplayer gparted dvb-apps leafpad mc qiv qpdfview kodi mplayer libreoffice gkrellm xscreensaver stellarium speedcrunch gimp inkscape
Run vlc like root user...
https://www.tecmint.com/run-vlc-media-p ... -in-linux/
sed -i 's/geteuid/getppid/' /usr/bin/vlc
Run chromium like root user...
chromium --no-sandbox
Wifi is working fine 2.4 and 5Ghz.
BT config...
https://wiki.debian.org/BluetoothUser
apt-get install bluetooth bluez bluez-tools rfkill blueman pulseaudio-module-bluetooth
systemctl enable bluetooth
service bluetooth start
Now go to ... Settings > Bluetooth manager
Ethernet is fine.
Desktop is very responsive but youtube chromium and firefox is slow at 1080p.
Kodi is slow.Not gui accelerated.
Overall performance is very good and is a system very usable.
You can change default password with command...
passwd
If you don't like running like root you can create an unpriviliged user.
The rpi4 is working fine on kali linux.
Note:
leafpad /boot/config.txt
disable_overscan=1
gpu_mem=192
and adjust overscan and gpu_mem an others parameters like on raspbian.
Return to “Other”
