Blazinfatherted
GazOS32-Kali-arm-PI4
Mon Jul 08, 2019 11:25 am
After kali released its 32bit version I created my own image it can be downloaded from here:
https://drive.google.com/drive/folders/ ... 3qDOEpOOIW
Username is root
Password is GazOS
Please take time to read the readme file
It was built on the PI4 2 GB version but should work on the other two.
I do this in the hope it can be used in STEM activities and promote good security awareness. Please only use on yout networks or networks you have written permission to do so.
Enjoy
Blazinfatherted
Re: GazOS32-Kali-arm-PI4
Mon Jul 08, 2019 4:11 pm
Full App list can be found here: https://drive.google.com/drive/folders/ ... 4PFfQGRUTs
Includes Airgeddon and routersploit plus much much more.
Silentme
Tue Jul 23, 2019 3:38 pm
Outstanding....
I have a couple of questions if i may.
Can i pm you or just stick them in here?
K
DirkS
Tue Jul 23, 2019 7:08 pm
Can i pm you
No, you cannot. PMs are disabled
Silentme
Wed Jul 24, 2019 2:14 pm
I am on [email protected] if you can drop a line if not then that's ok.
It was questions surrounding how i can change the display properties as i cannot get off the settings you have and i cannot locate the files i need to alter.
Also if i was to run a totally virgin download of this product via the Kali Arm image, i have tried lots of commands to attempt to get the full Kali product applications, but to no avail.
Any help would be gratefully received.
K
Blazinfatherted
Fri Aug 09, 2019 6:53 pm
Hi, I have made some changes to the settings, for some reason dual monitors are not working that's to be fixed to change the screen settings you have to update the text files. I am in the process of packaging a new image so when that's done I post the config here.
Just for notes please add any suggestions to this thread or email
[email protected]
Also please post any tool suggestions.
Best regards
Blazinfatherted
Fri Aug 09, 2019 7:18 pm
This is Follow this guide to update the screen settings
https://dephace.com/change-screen-resol ... erry-pi-3/
Works for the PI4 32bit image as well.
At the moment dual screens are not possible.
drushtx
Contact: Website Yahoo Messenger Facebook YouTube
Wed Aug 14, 2019 4:02 pm
Have GazOS32 Kali up and running on Pi4 with 1GB and the wireless interface. Working great. Would like to run headless/graphical. Can't install RealVNC - error during initial installation step indicates conflicting program. I take that to mean that there is another rdp/vnc/etc. server running. But I can't figure it out. Nothing visible in service or netstat --listening. Any ideas? Thanks!
Originally posted 14 Aug. It is now 17 Aug. No response from Blazinfatherted or other users. Emailed Blazin' on 14 Aug and again on 26 Aug. No reply in either case. So, generally a nice release but with no support, it cannot be used reliably in a production environment. Many thanks to Blazin' for the good effort.
Return to “Other”
