Stecco
All ports become very hot on Kali Linux
Sat Jun 15, 2019 3:53 pm
Some days ago i installed in the raspberry pi model 3B+ Kali Linux (the one specifically built for raspberry pi), i don't know why (and if this is a normal problem or not) but every single port (HDMI, USB and the Power Cable) become very hot, how can i fix this (if this is a problem)? Also the CPU temperature when i used Raspbian was around 55°C now it is 68°C (i know that Kali Linux needs far more computing than Raspbian but this seems to me a lot more than it should be).
Re: All ports become very hot on Kali Linux
Sun Jun 16, 2019 3:05 am
68°C is not excessively hot for a Pi 3B+, but the CPUs may run slower at that temperature. The temperature limit is 85°C. It is expected that the ports will become warm as they are used as part of the thermal management on the 3B+, excess heat is channelled through the board to the metalwork of the ports.
khaledboub
Tue Jun 18, 2019 11:03 am
Kali linux needs more computing than Raspbian, you can use fan or radiator to fix this problem.
Return to “Other”
