RPI 3 A+ does not boot
Posted: Mon Mar 04, 2019 2:48 am
by vcapeluto
Hey guys,
I have installed Windows 10 IoT and Ubuntu Mate 16.04 and the Pi does not boot following all the instructions from the documentation, does anybody know if there's any trick on this or something?
Re: RPI 3 A+ does not boot
Posted: Mon Mar 04, 2019 3:29 am
by DavidS
Hey guys,
How did you write the images to the SD Card?
Also have you tried Raspbian?
Posted: Mon Mar 04, 2019 4:11 am
by DougieLawson
It's most likely that your version of Mate doesn't have the right bootcode & firmware for the newest Raspberry.
You need a version built after 16th November 2018.
Posted: Mon Mar 04, 2019 5:23 pm
by vcapeluto
Hey guys,
I wrote Windows IoT with the IoT Dashboard app and Ubuntu with the app Win32 Disk manager
Posted: Mon Mar 04, 2019 5:24 pm
by vcapeluto
Is there an available version built after 16th November 2018?
Posted: Mon Mar 04, 2019 5:30 pm
by code_exec
No, although there will be.
Posted: Mon Mar 04, 2019 6:00 pm
by fruitoftheloom
Hey guys,
Regards Windows 10 IoT Core you will need the latest Insider Preview and hope that Microsoft Developers have updated the the kernel / firmware to support the 3A+
You will need a Microsoft Account to download, it seems the latest version is 17763:
https://docs.microsoft.com/en-us/window ... commercial
https://www.microsoft.com/en-us/softwar ... windowsiot
https://social.msdn.microsoft.com/forum ... WindowsIoT
Posted: Mon Mar 04, 2019 6:12 pm
by feelslikeautumn
Still probably won't boot out the box. The version of firmware is from September. You would have to https://wiki.ubuntu.com/ARM/RaspberryPi ... ader_files and copy a dtb file for the 3a+ if one doesn't exist. You don't have a lot of memory on the 3a+.
Posted: Mon Mar 04, 2019 9:07 pm
by code_exec
But those copies of the bootloader files are from April 2018. You'll need bootloader files from November 2018 for it to boot on the 3A+.
It doesn't seem like flash-kernel will work on the Pi 3A+ out of the box either as there appears to be no entry in the database for the 3A+.
Posted: Tue Mar 05, 2019 10:31 am
by jamesh
Hey guys,
Does the Pi boot when using Raspbian?
