sarathjayanthan
Cannot SSH RPi3 over WiFi, [with Ubuntu Mate] but can ping
Wed Aug 01, 2018 12:59 pm
I am using Raspberry Pi 3 with Ubuntu Mate 16. I am interested to establish an SSH connection between my laptop and RPi3 through WiFi.
Both my laptop and RPi3 have been connected to the same WiFi network, without internet. I have edited the .bashrc files and enabled SSH in sudo raspi-config. I am able to ping the RPi3 from laptop, but I cannot establish an SSH connection. When I try SSH connection, it does not show any error but just stays blank until I press Ctrl+C.
Is this because I do not have Internet connection in my WiFi Network? Can somebody help?
Thanks.
tpyo kingg
Re: Cannot SSH RPi3 over WiFi, but can ping
Wed Aug 01, 2018 1:03 pm
Editing .bashrc should not be relevant to SSH.
About the SSH connection, when you connect to the client using -v, or -v -v, or -v -v -v for extra information, does it provide any output?
sarathjayanthan
Wed Aug 01, 2018 1:10 pm
When I run : ssh -v -v -v [email protected]_ip_address, I get the below output:
OpenSSH_7.2p2 Ubuntu-4ubuntu2.4, OpenSSL 1.0.2g 1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "client_ip_address" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to client_ip_address [client_ip_address] port 22.
Ernst
Wed Aug 01, 2018 1:17 pm
You can ping, do you receive pong ? What are the statistics ? Please show.
Please provide the output from the following commands executed on your Pi:
ifconfig
route
I have the absurd idea that there is an unconnected fixed IP address wired ethernet interface that might be involved.
sarathjayanthan
Wed Aug 01, 2018 1:31 pm
Yes the Ping was successful, the message packets were received, if that is what you meant.
ifconfig
route
I have the absurd idea that there is an unconnected wired ethernet interface that might be involved.
Output for $ifconfig :
enp0s29u1u1c4i2 Link encap:Ethernet HWaddr 32:f7:c5:99:63:dc
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
enp9s0 Link encap:Ethernet HWaddr 78:84:3c:9e:b2:d1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2478 errors:0 dropped:0 overruns:0 frame:0
TX packets:2478 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:198573 (198.5 KB) TX bytes:198573 (198.5 KB)
wlp2s0 Link encap:Ethernet HWaddr cc:af:78:bd:52:f9
inet addr: <ip_address> Bcast:192.168.178.255 Mask:255.255.255.0
inet6 addr: fe80::d909:5b5f:9b0e:6e3d/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:11430 errors:0 dropped:0 overruns:0 frame:0
TX packets:13189 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4464749 (4.4 MB) TX bytes:4130276 (4.1 MB)
Output for $route :
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default fritz.box 0.0.0.0 UG 600 0 0 wlp2s0
192.168.178.0 * 255.255.255.0 U 600 0 0 wlp2s0
Ernst
Wed Aug 01, 2018 1:59 pm
Wed Aug 01, 2018 1:56 pm
The solution in this link worked for me : https://unix.stackexchange.com/question ... an-ping-it
What solution, please give details.
Return to “Other”
