sayhello
how to edit the /usr/share/X11/xorg.conf.d/11-evdev.conf file
Tue Jul 31, 2018 11:41 am
hi there dear community
my notebook (akoya e4254 the touchpad and clickpad mouse is not working at all.
here in this path i have the both files:
see the path; /etc/X11/xorg.conf.d/
i have
[[email protected] xorg.conf.d]$ ls -l
insgesamt 4
-rw-r--r-- 1 root root 266 24. Jul 23:52 00-keyboard.conf
-rw-r--r-- 1 root root 0 26. Jul 22:38 30-touchpad.conf
question:
how could I edit the "on" to the /usr/share/X11/xorg.conf.d/11-evdev.conf file?
Section "InputClass"
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
EndSection
I have read on a lot of threads about this issue.
If editing this file /usr/share/X11/xorg.conf.d/11-evdev.conf is ok, what is the best method?
1) sudo nano /usr/share/X11/xorg.conf.d/11-evdev.conf
2) sudo gedit /usr/share/X11/xorg.conf.d/11-evdev.conf
3) from files simply follow path to -evdev.conf file and edit and save
sayhello
Re: how to edit the /usr/share/X11/xorg.conf.d/11-evdev.conf file
Tue Jul 31, 2018 12:18 pm
by the way - where does this file reside
DirkS
Tue Jul 31, 2018 12:23 pm
Is this about 'Debian Stretch with Raspberry Pi Desktop' from https://www.raspberrypi.org/downloads/r ... i-desktop/ ?
klricks
Tue Jul 31, 2018 12:33 pm
This is what I would do. Quickest and easiest.
If you have installed gedit then this will work.
Or use leafpad which is already installed
sudo leafpad
This will not work as sudo must be used to edit any system file.
Use this instead.
sudo pcmanfm
Return to “Other”
