boomonster
Installing Windows XP in Qemu on the Raspberry Pi 2?
Fri Jun 08, 2018 8:47 pm
Hi there,
I am just curious if it is possible to
install Windows XP in the Qemu VM
on the raspberry pi 2. :P I have tried several
times, but the Qemu window went "poof"
and the terminal that I was running it in
said that there was some wierd 0x00324
or whatever error. :? I do not know how to
get past this... :x If the command I was using
to Qemu XP would help, here it is:
qemu-system-i386 -drive file=XPPROFESS.qcow2,format=raw,index=2,media=disk -drive file=WINDOWS_XP_PROFESS.ISO,if=ide,media=cdrom,index=3 -m 512
Please help! :)
Boomonster
Re: Installing Windows XP in Qemu on the Raspberry Pi 2?
Fri Jun 08, 2018 9:12 pm
Hi there,
Please help! :)
Boomonster
As in your other posts, the answer always is that you have bought the wrong Single Board Computer for your usage.
http://www.up-board.org/upsquared/
Even IF you can get XP running in a VM the boot time would be at least 10 minutes
https://youtu.be/hPAvybmy1Bk
adieu
My other Computer is an Asus CS10 ChromeBit
Return to “Other”
