Laui
Kodi
Fri Jun 01, 2018 9:34 pm
Hi, Kodi 8.0.3 doesnt play some Videos and i dont know why.
Doesnt play
General
Complete name                            : v1.flv
Format                                   : Flash Video
File size                                : 67.8 MiB
Duration                                 : 23 min 50 s
Overall bit rate                         : 398 kb/s
Tagged date                              : UTC 2016-07-22 01:53:30
Tagging application                      : flvtool++ (Facebook, Motion project, dweatherford)
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings, CABAC                   : No
Format settings, ReFrames                : 3 frames
Codec ID                                 : 7
Bit rate                                 : 332 kb/s
Width                                    : 428 pixels
Height                                   : 240 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 24.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.135
Stream size                              : 56.6 MiB (84%)
Writing library                          : x264 core 125
Encoding settings                        : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=512 / vbv_bufsize=512 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 10
Bit rate                                 : 56.8 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 spf)
Compression mode                         : Lossy
Stream size                              : 9.68 MiB (14%)
General
Complete name                            : v2.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/avc1/mp41)
File size                                : 50.4 MiB
Duration                                 : 12 min 15 s
Overall bit rate                         : 575 kb/s
Encoded date                             : UTC 1904-01-01 00:00:00
Tagged date                              : UTC 1904-01-01 00:00:00
Writing application                      : Lavf56.40.101
Video
Format                                   : AVC
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 512 kb/s
Width                                    : 426 pixels
Height                                   : 238 pixels
Frame rate                               : 29.970 (30000/1001) FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 44.9 MiB (89%)
Writing library                          : x264 core 136
Encoding settings                        : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=512 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : 40
Bit rate mode                            : Constant
Bit rate                                 : 56.0 kb/s
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 spf)
Stream size                              : 4.91 MiB (10%)
Default                                  : Yes
Alternate group                          : 1
General
Complete name                            :  v3.mp4
Format                                   : MPEG-4
File size                                : 32.6 MiB
Duration                                 : 5 min 33 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 819 kb/s
Encoded date                             : UTC 1970-01-01 00:00:00
Tagged date                              : UTC 1970-01-01 00:00:00
Writing application                      : Lavf52.93.0
Video
Format                                   : AVC
Format settings, CABAC                   : Yes
Codec ID                                 : avc1
Bit rate                                 : 768 kb/s
Width                                    : 720 pixels
Height                                   : 400 pixels
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.089
Stream size                              : 29.2 MiB (89%)
Writing library                          : x264 core 105 r1724 b02df7b
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=dia / subme=5 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / weightb=0 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=768 / ratetol=1.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : 40
Bit rate mode                            : Variable
Bit rate                                 : 80.8 kb/s
Stream size                              : 3.21 MiB (10%)
This works
General
Complete name                            : worksfine1.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (isom)
File size                                : 1.23 GiB
Duration                                 : 1 h 28 min
Overall bit rate                         : 1 992 kb/s
Encoded date                             : UTC 2017-11-08 11:22:17
Tagged date                              : UTC 2017-11-08 11:22:17
Video
Format                                   : AVC
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=1, N=33
Codec ID                                 : avc1
Bit rate                                 : 1 800 kb/s
Width                                    : 960 pixels
Height                                   : 540 pixels
Frame rate                               : 25.000 FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.139
Stream size                              : 1.11 GiB (90%)
Language                                 : English
Color range                              : Limited
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : 40
Bit rate                                 : 192 kb/s
Maximum bit rate                         : 567 kb/s
Stream size                              : 120 MiB (10%)
Language                                 : English
or
General
Unique ID                                : 234848754377470062680137158353462195940 (0xB0AE398F7DE739DDB55F7394027776E4)
Complete name                            : worksfine2.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 1.48 GiB
Duration                                 : 2 h 3 min
Overall bit rate                         : 1 726 kb/s
Encoded date                             : UTC 2016-11-03 09:11:59
Writing application                      : mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun  9 2014 15:16:27
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                                   : AVC
Format settings, ReFrames                : 8 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 1 500 kb/s
Width                                    : 720 pixels
Height                                   : 304 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.286
Stream size                              : 1.29 GiB (87%)
Writing library                          : x264 core 144 r2525 40bb568
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.10 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                                 : Italian
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Bit rate                                 : 224 kb/s
Frame rate                               : 31.250 FPS (1536 spf)
Bit depth                                : 16 bits
Stream size                              : 197 MiB (13%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 58 min 25 s
Bit rate                                 : 0 b/s
Count of elements                        : 10
Stream size                              : 232 Bytes (0%)
Title                                    : German (forced)
Language                                 : German
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : en:1
00:04:06.000                             : en:2
00:08:23.000                             : en:3
00:13:34.000                             : en:4
00:18:30.000                             : en:5
00:24:09.000                             : en:6
00:29:20.000                             : en:7
00:36:17.000                             : en:8
00:42:22.000                             : en:9
00:48:24.000                             : en:10
00:55:14.000                             : en:11
01:01:11.000                             : en:12
01:08:29.000                             : en:13
01:16:25.000                             : en:14
01:24:47.000                             : en:15
01:29:08.000                             : en:16
01:37:54.000                             : en:17
01:44:28.000                             : en:18
01:48:05.000                             : en:19
01:54:03.000                             : en:20
Why?
DirkS
Re: Kodi
Fri Jun 01, 2018 9:57 pm
Kodi 8.0.3
Current version is 17.x
Laui
Re: Kodi
Sat Jun 02, 2018 7:32 am
OpenELEC 8.0.3
Imperf3kt
Re: Kodi
Sat Jun 02, 2018 7:40 am
You'll notice the files that don't work are all showing as "mpeg-4" format
It seems to me, these files need to be muxed into a container and not simply renamed.
I suggest downloading a muxing program (YAMB, MP4BOX, MKVmergeGUI, etc) and passing the files through before trying again.
This process does not encode anything, and should only take a few seconds to a few minutes (your files will take seconds)
All files seem to use h.264 (except the .flv - that uses h.263) so muxing them into either .mp4 or .mkv is recommended
I personally prefer mkvmerge, but any of the listed programs will work. I am not sure if these programs are multi-platform though. They work on Windows, but I have never tried them on other systems.
Google is ubiquitous - learn to use it!
https://opensource.com/life/16/10/how-ask-technical-questions
Return to “Other”
